End Link Options for G37xS
Old Apr 7, 2017 | 10:52 AM
G37xS-Life's Avatar
G37xS-Life
I am planning to upgrade my front and rear sway bars to the Hotchkis. Having done some research, a few have recommended also upgrading the end links as well.
The consensus is that SPL Pro end links are the best out in the market right now. However, SPL Pro End links are only available for the rear when it comes to a G37xS coupe (unless I have mistaken).
What would be the next best alternative for the front end links other than the SPL Pro?
Old Apr 7, 2017 | 11:18 AM
Baadnewsburr's Avatar
Baadnewsburr
Presuming you're looking for adjustable ones (so you can get rid of preload if you change ride hheight) besides the SPL front end-links for the g37 (Coupe and sedan)/370z[ part # SPL FE Z34] the only other ones I have been able to find are from Moonface but they were almost $500.00 a set last time I checked.
If you dig into some really old threads on here there used to be one or two more alternatives (including a member on here that made them) but I haven't seen an update from those sources in years and don't know how active they are.
one caveat, some sources i have seen say they don't fit the AWD model but I'm not sure how accurate that is.
If you aren't looking for adjustable, there are lots of aftermarket options, a lot of people on here seem to prefer Moog as they are greasable, but I had them for a while and didn't care for them.
Old Apr 11, 2017 | 08:52 AM
Surfnazi's Avatar
Surfnazi
You can make your own you just need heim joints 4 of them and center shaft any auto race part store has all this in stock. 30 bucks and you can make a set just remember without the oem rubber hat has grease on the joint it will make clicking noise
Old Apr 11, 2017 | 09:29 AM
Baadnewsburr
Do you have any specs (measurements) on the parts required?
Old Apr 12, 2017 | 03:58 AM
Surfnazi's Avatar
Surfnazi
Well I can take some but if you measure your stock ones and allow for 2 inches on each end for adjustment you can figure out your middle shaft
Old Apr 12, 2017 | 09:08 AM
zer099's Avatar
zer099
This might help you: LINK
Old Apr 12, 2017 | 09:36 AM
j50ny's Avatar
j50ny
^^I remember that write up. It was great. OP...if you are able to do this, it would probably be a better option than trying to source a set of decent end links for the AWD.
Old Apr 13, 2017 | 06:02 AM
Surfnazi's Avatar
Surfnazi
I'll go to smileys in Dallas and pull the parts and take pics. Last set I built took more time finding the heim joints I wanted. Iirc 4 joints 2 shafts 8 locking nuts
Old Apr 13, 2017 | 06:11 AM
Surfnazi's Avatar
Surfnazi
If there is enough interest I'll make like a 20 batch build no overhead just flat fee for parts and shipping need to price out all the parts
Old Apr 13, 2017 | 10:44 AM
ratso000's Avatar
ratso000
I've had the Hotchkis sways and also all of the GTspec subframe bracing...I'm riding on stock end links in New Orleans with the worst streets in existence for over a year now with no issues...that year driving highway and city was 25k miles..about 50% each....
Old Apr 13, 2017 | 11:06 AM
zer099's Avatar
zer099
End-links should only be needed if you lower your car so you can adjust the pre-load out of your sway-bars. That's pretty much the only purpose they serve along with linking the sway-bar to the chassis/knuckle. Better (read: beefier) quality end-links will deflect less under load as well, of course.
Old Oct 24, 2020 | 09:55 PM
kkongoo's Avatar
kkongoo
Surfnazi,
I know this is old thread. Just wanted to know if you made additional front end links for sale as I am planning to replace mine soon. My car is 2010 G37xs
