What did you do to your coupe today?
Old May 7, 2022 | 03:39 AM
  #2026
Ginge247's Avatar
Ginge247
Diff and prop shaft out
Diff and prop shaft out to replace the diff bushes, output shaft seal on the 7AT and fit a new centre bearing on the prop (main) drive shaft 🙄
Old May 7, 2022 | 10:11 AM
  #2027
CWorksDesign's Avatar
CWorksDesign
Added my super tank with sight glass so you can see the Smurf juice. This is going to a client of mine but I’m loving mine in my g37 coupe as well. More coolant for those track guys and hot climate living fellas.
Old May 7, 2022 | 11:45 PM
  #2028
Deannie's Avatar
Deannie
Stared at it longingly
Today (and yesterday), I stared longingly at my G. It’s been pouring (never driven in the wet) so I watched the rain matt down the beech tree pollen puffs atop the thoroughly soaked car cover as it hugs her every curve. Well, it’s raining tomorrow too, so that means it won’t be until the following weekend I get to row her through the gears. Oops! I live in Maryland so there’s rain next weekend too. You Cali people don’t know how good you have it.
Old May 8, 2022 | 08:26 PM
  #2029
AdamBritt's Avatar
AdamBritt
I got JDM tail lights from a member on here almost two years ago and finally got around to installing them. I put the Bluebat overlays on them around then too and wasn't sure if I was going to like it but I did a mostly good job and I'm glad I didn't take them off before installing. I also put in LED lights for the turn and reverse lights from Diode Dynamics and am pretty happy I didn't mess anything up since I was doing some trial and error with how to connect the ohm resistors.
Old May 9, 2022 | 05:06 PM
  #2030
digital.aaron's Avatar
digital.aaron
I bit the bullet and acknowledged that I screwed up when ordering wheels for my xS coupe. Hopefully I'll be able to off-load them and recoup most of my money back. I went ahead and ordered wheels and tires that will fit better, but I won't see them for about two weeks. Almost have everything to take the car in and get the adjustable suspension installed, though. Just waiting for the coilovers to get here on Wednesday. Then I'll be getting front & rear camber arms, rear toe arms, and front & rear adjustable sway bar links. I'll probably keep everything as close to stock as possible until the new wheels and tires get here.
Old May 15, 2022 | 05:59 PM
  #2031
digital.aaron
New wheels arrived today. First one out of the box had a huge gouge in the lip.
Old May 17, 2022 | 05:01 PM
  #2032
digital.aaron
Dropped the car off to have the coilovers and adjustable camber & toe arms installed. Super excited for this install. Even the guy that works at the local gas station wants me to bring the car by when the install is done, lol.
Old May 26, 2022 | 09:41 PM
  #2033
digital.aaron
Got the alignment done today. 19x11 et22 all around on 275/35s. fronts were at max factory spec negative camber and within spec for toe (don't have the sheet in front of me for exact numbers). Rears were at factory toe, but at -5 for camber, because i need all the clearance I can get. I'll probably be trimming the bumper tabs more this weekend.
And as I half expected, I'm now on that most slippery of slopes with suspension mods. I'm already looking at the best tie rod end replacements (thinking z1 or GKTech), lowkey desperate for the Moonface RC correction and LA adapters, as well as trying to justify to myself how spending $2.1k for the FDF rear grip kit is actually a good idea, even though I just put on adjustable camber and toe arms on the rear.
I probably need to make a build thread...
Old May 27, 2022 | 07:45 AM
  #2034
That's a good idea.
-5° rear camber? That's stance nation territory. Can't imagine how that looks right, but maybe. Let's see it.
Old May 27, 2022 | 11:54 AM
  #2035
digital.aaron
That's a good idea.
Old May 27, 2022 | 12:03 PM
  #2036
I was expecting it to look goofy, but it actually looks fantastic! That's -5°? Doesn't look like it at all in these pics.
Wow! So much rubber... OMG. And such a pretty blue, too.
Old May 27, 2022 | 12:15 PM
  #2037
digital.aaron
I'll get another pic straight-on from the rear, that's where you can really see the negative camber. I was a little worried about running so much tire with the amount of poke I have, but I got a good deal on the tires, so I decided to take the chance, lol.
It was funny when I brought the car home, though. Two days after I had the G37, my neighbor went out and got an Aegaean Blue Honda Civic.
Old May 31, 2022 | 11:02 AM
  #2038
BULL's Avatar
BULL
Moderador
On another note XM radio is free for the next month.
Old May 31, 2022 | 06:41 PM
  #2039
Dentt42's Avatar
Dentt42
Damn, I’m going to miss the constant stream of advertisements to sign up while I’m flipping through audio sources.
Old Jun 25, 2022 | 01:25 PM
  #2040
AWilson136's Avatar
AWilson136
Can I see what your g looks like with the enkei pf05s I'm thinking of getting a set.
