100k Service
Old Mar 20, 2016 | 01:26 AM
chadwick's Avatar
chadwick
100k Service
Sorry ahead of time, I'm sure this has been discussed before, but for some damn reason nothing I search for on the search bar comes up. what are the recommended services that I need to do at 100k? More specifically, if I took the car to the dealer today, what would they do to the car that I can most likely just take care of myself?
08' G37 Coupe non-S
Old Mar 20, 2016 | 01:28 AM
ZOSTER33's Avatar
ZOSTER33
08' G37 Coupe non-S
Check your owners manual for that and why would you take it to the stealership for service?
Do the work yourself or find a good local mechanic that can do all that work for you.
Old Mar 20, 2016 | 10:23 AM
Here you go a quick 10 second Google search
https://www.myg37.com/forums/g37-cou...intenance.html
Old Mar 20, 2016 | 11:28 AM
VenomGT9's Avatar
VenomGT9
DIY all day
Old Mar 20, 2016 | 12:28 PM
Glenn2008's Avatar
Glenn2008
As Venom said, DIY, nothing difficult. My '08 has just turned 90K and I've already done all of the recommended "severe" maintenance @80K. I'm not having any problems with the clutch, but when it hits 100K, I'm going to install the aftermarket slave, along with a new clutch, PP, and TO bearing.
Old Mar 21, 2016 | 11:46 PM
crookncastle's Avatar
crookncastle
flip open your owners manual and start reading it.
Old Mar 24, 2016 | 12:32 PM
Kris9884's Avatar
Kris9884
As far as searching is concerned, I read unless there's obvious wear or stretch, there's practically no reason to ever have to change the timing chain. True?
Old Mar 24, 2016 | 01:23 PM
Waste86's Avatar
Waste86
True, but if you are going to be doing other things in the timing area (tensioner, idler, and such) you might as well change all the things in there. If you have 100k miles and you are opening the front timing cover to look at wear on the chain, might as well replace it at that mileage.
andrialc2002
General Tech Questions
Mar 8, 2016 12:04 PM
Mr_Mer
Mar 7, 2016 08:39 PM
G37bruh
Mar 7, 2016 08:26 PM
isosunrise
Mar 1, 2016 10:10 PM
SkyG37
Feb 24, 2016 04:42 PM
