Car will not start
Old Mar 6, 2016 | 02:55 PM
Mr_Mer's Avatar
Mr_Mer
Car will not start
So I am trying to leave the gym, unlock car, press break, push button... all lights on dash come up, all sort of chirps from the dashboard start, but car won't.
Break pedal is now quite hard to push in, no response to the fob, can't lock it, open trunk, radio won't turn on. Just all lights on the dash.
Help.
Old Mar 6, 2016 | 03:01 PM
JeffG37x's Avatar
JeffG37x
Maybe starter? You can test it to see if that is the problem.
Old Mar 6, 2016 | 03:05 PM
Mr_Mer's Avatar
Mr_Mer
No tools or anything to help me out here. All the dash lights on is weird. Is even telling me the door is open when it is not.
Old Mar 6, 2016 | 04:28 PM
johnnyn's Avatar
johnnyn
Help.
Have you tried disconnecting the battery for a few minutes?
Old Mar 6, 2016 | 04:43 PM
JeffG37x's Avatar
JeffG37x
I was leaning towards battery is good but have you tried jumping it. Also are you getting any clicking etc... There are typically a few basic cases why a car won't start. Is it cranking at least, starting and then going out, just not turning over, etc...
My last car would only start if I turned the car off at a good point. If I didn't it would take me forever to get it running again.
Old Mar 6, 2016 | 05:25 PM
Mr_Mer's Avatar
Mr_Mer
There were no clicks. I disconnected the battery, waited a few minutes and reconnected it. Immediately went haywire again. Checked voltage with voltmeter, good 13v at battery. Had it towed to dealer, just before they closed. Seems to be an ECU malfunction of some sort. More later this week.
Old Mar 6, 2016 | 06:01 PM
Epiphany's Avatar
Epiphany
Dead battery possibly. Get a boost and see if that works.
Old Mar 6, 2016 | 08:23 PM
JeffG37x's Avatar
JeffG37x
Good thing you got it in now they can work on it first thing tomorrow. Keep us posted and let's hope it is no big deal .
Old Mar 6, 2016 | 08:49 PM
You should've tried getting a jump starts prior to towing it to the dealership. Hopefully they don't charge you to much if it's nothing major and with that being said hopefully it isn't something major. Best of luck man keep us posted.
Old Mar 7, 2016 | 07:40 AM
Mr_Mer's Avatar
Mr_Mer
It is good to know someone at the dealership... they have started working on it bright and early.
They have tried to jump start it and nothing...
Disconnecting the battery seems to have done the trick... a quick "reset" of all electrical systems, if you will. They will perform some diagnostics as the day goes by.
So far the dealer reports that they cannot open the gas door. Maybe there is a short there and it is causing all sorts of havoc on the electrical system. More as it develops.
Old Mar 7, 2016 | 08:21 AM
Very good to hear man hopefully you'll have the car back in no time!
Old Mar 7, 2016 | 09:38 AM
si_driver's Avatar
si_driver
Hey,
Read my post from the link below. . make sure that it doesn't apply to your car. check your vin etc .... The dealer didn't know about this until I found the issue.
https://www.myg37.com/forums/g37-sed...f-problem.html
The ITB which applies is ITB12-024.
Old Mar 7, 2016 | 07:52 PM
Mr_Mer's Avatar
Mr_Mer
Originally Posted by si_driver
Hey,
Thank you! Let the dealer know about this. It seems it was applied already.
In the end, it was a short on the "fuel lid door actuator" that in turn sent the BCM crazy. They need to reprogram the BCM and FOBs (tomorrow), order the actuator (all the way from Japan), and I should have the car good to go before mine and my wife anniversary trip this weekend. $100 deductible, rental car covered, still $367.34 out of pocket. Not bad for an electrical part.
Old Mar 7, 2016 | 08:39 PM
2008G-Man's Avatar
2008G-Man
FYI ... checking the car battery with a volt meter is pretty useless. Unless the battery is totally shot to hell you will almost always read decent voltage. True test is a load test and also check voltage with car running to see if you are getting good charging voltage (roughly 14-14.5 volts). I know you couldn't do either of those in this case.
Paul_G37
Nov 28, 2020 06:49 PM
Maelstrom
Feb 29, 2016 02:11 PM
boxtwo
Feb 27, 2016 11:50 AM
SkyG37
Feb 24, 2016 04:42 PM
Mattlorentzoe
13
Feb 23, 2016 07:31 PM
