Did I not notice this before??
Hi all, I recently had a front end accident and my car has been fixed. However, I was curious about two things which may or may not be an issue, to put my mind at ease.
Number one is the cooling/radiator fans. Whenever you turn the air conditioner on, the fan(s) come on to keep the condenser and engine bay cool and there is a louder "drone" as either an additional fan comes on, or the fans spin faster. However, when I turn the a/c off the fan cycles on and off every 5 seconds. This only happens after a drive so maybe I'm paranoid and just didn't notice it sooner. Any ideas?
Number 2, one of my headlights was replaced and I noticed it gives off a blue tinge. The unreplaced headlight is bright white. Does the new HID bulb eventually lose color? It's slightly brighter so I'm wondering if the body shop put in a brighter bulb or if that's just because it's a newer headlight. The blue tinge is only noticeable on the back of cars I'm following, but barely if I look at the headlights from a far. Any ideas?
Thanks for the help everyone!
Amaadkhan2k (09-17-2015)
Amaadkhan2k (10-08-2015)
Idk if this relates much but after I dropped my Ducati Last year (low speed slide, only fairings replaced) I started to notice the belts more. I was paranoid but eventually came to accept that is the nature of the beast as all Ducatis have loud belts. I mark it down as a :im just looking for a reason to upgrade" thoughts.
Now for your bulb, it might be the difference of a new bulb vs old. Time to swap out for an upgrade.
Did i just not notice this before (cont) . . .
I wasn't familiar with the "fresnel" lens and looking online that makes a lot of sense. But stock i remember the lens giving off a blueish hue, so maybe they replaced the headlight and put in a different bulb too?
seems to be so, do you guys know if the lens is swappable vs the whole headlight?? I'm going to cause a fuss with the repair shop so hopefully they'll take care of it
I think it might be a combination of what Abramite and G-thirty7x were saying about the lens and a different bulb as well, bc i noticed the actual projector housing was glowing a lot brighter on the left headlight (the one with the "clear" lens)
RIGHT HEADLIGHT
LEFT HEADLIGHT
Thanks y'all!! if only everyone was as helpful as you guys in real life
If you wanted to check, you could switch the bulbs from side to side and see if the brighter side changes. They likely put a new bulb in when replacing the headlight so depending how old your other bulb is that might be the culprit.
resolved
Hi all!! I appreciate everyones contribution!
I took my car to infiniti for an oil change and the dealership took a look at both, determined there was an issue with the radiator fans, and the headlight was defective. The repair shop is going to take care of it all. Thanks for everyone's input!!!
parkern
10-05-2015 12:12 PM
r0cketm0nkey
09-27-2015 01:34 PM
