Slow 0-60, whats wrong?
Old Jun 27, 2015 | 02:29 PM
  #31
Broken Arrow's Avatar
Broken Arrow
Originally Posted by HoldmyMouse
Inertia. The weight of the wheel is spread out more on your 20s than stock 17s.
I think the prime example is an ice figure skaters when they do the spin move. When the skaters want to spin fast, they hold their arms closer to their body and slow down by extending their arms apart. The skater weights the same but speed can drastically changed by distributing the weight.
Also wider tires or sticky tires will create more rolling resistance
2010 X Coupe comes standard with 18" wheels, FYI.
Old Jun 29, 2015 | 01:17 AM
  #32
banklender's Avatar
banklender
Not so sure....
Originally Posted by dmg6768
Smaller wheels help with acceleration just by being smaller. Your car with 20's and 18's that weigh the same would be faster on the 18's. Bigger wheels, in a sense, change the gear ratio making your car accelerate slower but will have a slightly higher top speed. Smaller wheels have the opposite effect.
I disagree that wheel size in and of itself will change the effective gear ratio (i. e. The engine rpm vs.wheel rpm). It is the outside circumference of the TIRE that determines the engine rpm to wheel rpm.
Old Jul 24, 2015 | 01:24 AM
  #33
swadds77's Avatar
swadds77
Slow 0-60s G37S sedan
Hello,
I too have been experiencing 0-60 times in the 6.2-6.4 range in my 2010 G37s sedan (59400 miles). I'm not sure what could be causing the problem. I reset the ECU, as suggested above, as the car was preowned when I purchased it. The only modifications I have done to the vehicle is add a K&N intake and switched out the stock rims for 370z rims of the same size. Does anyone have any ideas? I would rather not have to drive 50 miles to my nearest dealer if at all possible, although I am more than willing at this point.
Old Jul 24, 2015 | 01:47 AM
  #34
Epiphany's Avatar
Epiphany
Originally Posted by swadds77
Hello,
How are you measuring your time? AT or MT? What tires do you have? How are you launching? What octane fuel? What's the temperature and humidity? What is your altitude? There are so many variables for something like that.
Old Jul 24, 2015 | 07:17 AM
  #35
Awgd8's Avatar
Awgd8
To get the quickest 0-60 time. Uprev cipher log could be the most accurate than a stopwatch.
1) 1/4 of gas in the tank.
2) light weight wheels and Tires setup. I lot of folks only look at wheel weight and disregard tire weight when shopping for tires) . This can varies from 17 ibs to 28 ibs unsprung weight.
3) all 4 tires have properly infated.
4) Remove junk in the trunk.
5) lose some weight...??☺️
6) use highest octane available.
Technical :
1) DS mode
2) only brake torque in less than 4 secs. Anytime you prolong the brake torque, the more the ecu will cut power during launch to prevent torque converter damage.
3) find the best rpm for brake torqueing that does not feel bogging down.
4) vdc off
5) engine warm but not too hot.
6) open hood and wait 10 mins for every run.
Your number cant be that slow.
My 2008 EX35 AWD 5 speed AT did 6.12 secs 0-60 Uprev Etuned stock engine just dry air filter. I used a Uprev Cipher 0-60 logging. This is a 4,000 pounds Crossover on a 17 " wheel/tire combo.
MrRiv
Sep 29, 2015 04:59 PM
si_driver
ECU Tuning / Dyno Data
24
Sep 29, 2015 11:38 AM
steven92
Sep 23, 2015 08:48 AM
deky_
Sep 12, 2015 11:02 AM
Mattlorentzoe
Sep 4, 2015 10:41 AM
