Q60 Final Teaser - Revealed in Detroit
Old Aug 17, 2016 | 01:54 PM
  #2701
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Originally Posted by eljoker
It put down 375hp and 349 lbs on the dyno.
Either it has just 7% drive-train loss.. lol, or its underrated
Old Aug 17, 2016 | 01:59 PM
  #2702
04gtoryder's Avatar
04gtoryder
Originally Posted by Ape Factory
The acceleration numbers are nearly identical to their instrument test of the 2015 mustang GT. I have to imagine the coupe will be essentially the same. These cars seem to pull really well with great top end speed. If only we got LSD.
  #2703
gill1606's Avatar
gill1606
yeah you are right, i just saw the video for myself, sorry I was going by what i read from someone else in the youtube comments section. previous post corrected.
Old Aug 17, 2016 | 02:22 PM
  #2704
Ape Factory's Avatar
Ape Factory
Originally Posted by gill1606
Here's a write up from Stillen in an attempt to analyze further tuning of the new VR 3.0 V6 twin turbo engine:
https://blog.stillen.com/2015/12/aft...twin-turbo-v6/
I actually posted a link to that way back when. But good refresher. I just hope it's easy to get the car into the 12's with just an exhaust (and LSD).
Old Aug 17, 2016 | 02:28 PM
  #2705
04gtoryder's Avatar
04gtoryder
There's a guy that was running consistent high 12's trapping around 112 on the q50 forums with a stock AWD RS400. 12's will definitely be doable stock in good conditions, especially with a set of drag radials.
Old Aug 17, 2016 | 02:29 PM
  #2706
gill1606's Avatar
gill1606
Well if stillen can work with this engine we should be seeing it soar past 400HP it would be a "everything killer" at that point lol for just about 50 grand. Not to mention other aftermarket parts and weight reduction
Old Aug 17, 2016 | 03:10 PM
  #2707
KAHBOOM's Avatar
KAHBOOM
the good thing is that a LSD can be purchased for the price of something like an exhaust system.. Another potential money-maker for aftermarket vendors... they should go ahead and jump on that. the Q50 is already out and can be used for R&D
Old Aug 17, 2016 | 03:32 PM
  #2708
SlateBlue G's Avatar
SlateBlue G
The real question now with direct injection is how bad the carbon build up will be. Hopefully they wont follow in VW/Audi footsteps
Old Aug 17, 2016 | 03:42 PM
  #2709
300ZXTT's Avatar
300ZXTT
Nice read.
Old Aug 17, 2016 | 03:44 PM
  #2710
eljoker's Avatar
eljoker
They went over that in training. Its a different design where it sprays after the valve to mitigate that if I recall right.
Old Aug 17, 2016 | 05:19 PM
  #2711
gill1606's Avatar
gill1606
for sure, the LSD should help alot with that time. a reviewer, auto alex specifically, mentioned that the RWD red sport had significant wheel spin affecting its 0-60 time and of course 1/4 mile time as well. The AWD version as mentioned above is able to consistently hit in the high 12 region just stock.
Old Aug 17, 2016 | 05:55 PM
  #2712
eljoker's Avatar
eljoker
Here is some specs from Infiniti.
http://www.infinitiusa.com/st/infini...upe.pdf#page=1
58/42 weight distribution. Damn what happen to almost 50/50?
Not Seeing 20s, wtf? So alot more $$$ just for 100hp more and almost no differences? This aint looking good.......
Old Aug 17, 2016 | 06:08 PM
  #2713
300ZXTT's Avatar
300ZXTT
58/42 power to weight. Damn what happen to almost 50/50?
No 20" wheel for RS400. Aftermarket wheel companies are lovin' that!
Also, I see the RWD RS400 comes in at a 'piggish' 3,862 pounds. And the AWD RS400 at a morbidly obese 4,024 pounds! Thought my IPL was heavy (which it IS) at 3,718#. Not so much anymore.
Also noticed it's only 1 inch wider than my IPL. The pictures make it look moreso. 1/2 inch shorter and same height (stock)
Old Aug 17, 2016 | 06:09 PM
  #2714
gill1606's Avatar
gill1606
are there like leather seats in the 400 that aren't in the 300? that could be like 2 grand by itself i think
Old Aug 17, 2016 | 06:15 PM
  #2715
gill1606's Avatar
gill1606
its not power to weight, its weight distribution percentage, the 58/42 means the car is 8% heavier toward the nose end and 8% lighter toward the rear end. 50/50 weight distribution means both front and rear ends carry the same percentage of weight, neither is a certain percentage heavier or lighter.
