Gas fill-up usually clicks off before full
Old Oct 22, 2014 | 09:58 PM
MPdesign's Avatar
MPdesign
When I am putting gas in the tank from any gas station, it usually clicks off a lot until I finally get it to work. Sometimes, I cannot get it to work on full flow and have to use a lower setting.
Any ideas why?
Old Oct 22, 2014 | 11:27 PM
ratherunique85's Avatar
ratherunique85
ived had the same thing happen to me a few times. It clicks off even on the lowest setting. Not sure why. anyone?
Old Oct 23, 2014 | 12:27 AM
HoldmyMouse's Avatar
HoldmyMouse
There's a TSB for that. Ref# ITB08-041a
Old Oct 23, 2014 | 03:16 AM
evil-G-nius's Avatar
evil-G-nius
Its vapor blow back. Basically the air left in the tank is getting pushed out when the fuel is being put in which turns the pump off. Its a safety mechanism, once it clicks I find there is still about 1-2 dollars left that will fit. You just have to be careful not to overflow though
Old Oct 23, 2014 | 02:00 PM
PanzMan's Avatar
PanzMan
I have had this issue several times. Here in NJ you are not allowed to pump your own gas. One attendant showed me if you put the handle in the tank upside down (looks weird) it does not kick off. Sure enough every time I have this issue this seems to work.
Old Oct 23, 2014 | 02:15 PM
Redfire32's Avatar
Redfire32
Ginger ninja
Interesting. I have had the same problem with mine as well. Next time it acts up I'll give the upside down trick a try
Old Oct 24, 2014 | 02:36 AM
evil-G-nius
Watch doing that ish...like I said it can overflow and make a huge mess
Old Oct 25, 2014 | 01:29 PM
farmurr's Avatar
farmurr
I've only had this happen 2-3 times in the past 2 years. Just stop pumping, pull the handle all the way out, wait 5 seconds and start over...this 'fixed' the issue for me.
Old Oct 26, 2014 | 10:09 AM
telcoman's Avatar
telcoman
I've experienced the problem a few times at stations out of state on my way to Florida along I95. I usually make a note of the stations and never go back.
This is a new station that opened a couple of years ago near my house and I've never experienced the problem as I usually purchase all my gas here.
Telcoman
Old Oct 26, 2014 | 11:40 AM
warped ideas's Avatar
warped ideas
A quarter past stripped
I too have had this issue. I used my garage air compressor and a blower tip to blow compressed air into the little vent hole below the filler port WITH THE GAS CAP REMOVED! I usually just put the trigger on the fuel dispencer on the second fastest filling selector and it doesn't cause the gun to shut off prematuraly. I quit having this issue after the compressor trick.
Old Oct 26, 2014 | 11:42 AM
warped ideas
Telcoman
$3.11 Road trips for gas from now on, for me.....
Old Oct 26, 2014 | 12:22 PM
telcoman's Avatar
telcoman
Today's price is $2.73 for regular and $3.09 for premium
Old Oct 28, 2014 | 10:26 PM
BLAKonBLAKG37's Avatar
BLAKonBLAKG37
Doesn't Infiniti fix this issue for free by installing a bracket???
misc
29
May 24, 2023 03:57 PM
vamarris
Dec 9, 2018 11:10 AM
linvbro
Aug 22, 2016 01:25 PM
MrRiv
Sep 29, 2015 04:59 PM
si_driver
ECU Tuning / Dyno Data
24
Sep 29, 2015 11:38 AM
