What to watch for when buying G37
Old Jun 30, 2014 | 08:05 AM
901G's Avatar
901G
I am hoping to officially join the G37 family in the next few weeks. I am looking for a 2008-2010 G37 coupe (hopefully an S)! What are some common problems with these cars to look for when buying? Any tips would be great, thanks!
Old Jun 30, 2014 | 11:26 AM
PongSanity's Avatar
PongSanity
The biggest issue with joining the G37 family u ask?
choosing which one u want.... base... journey... X ... S... coupe... sedan....
Old Jun 30, 2014 | 11:28 AM
dholmblad's Avatar
dholmblad
When buying any used vehicle you should always make sure they have new: tires, breaks , rotors. These pieces are wear items and will cost you big if you need to replace them shortly after ownership.
Old Jun 30, 2014 | 08:25 PM
interalian's Avatar
interalian
Disagree on new tires - new tires can cover up problems with alignment, worn suspension parts and even frame damage. I'd much rather see a matched set of nicely worn tires.
The other items mentioned would be nice to see, but, realistically, who in their right mind is going to do THAT much maintenance then immediately sell the car?
Old Jul 2, 2014 | 02:06 PM
logan_franchise's Avatar
logan_franchise
I would have your mechanic go with you to do an inspection on the g37. So you can know if has been modded and abused. Good luck!
Old Jul 2, 2014 | 02:49 PM
toddmorr's Avatar
toddmorr
yeah...tires, brakes, rotors...nice to have those in good shape but in reality they are quite reasonable to replace. I"d almost prefer to have them in bad shape and use that as bargaining chip on price.
i'd focus on stuff like clutch, electronics, etc
Old Jul 3, 2014 | 04:12 PM
Omarg35's Avatar
Omarg35
^correct. Depending on how savvy you are around are car, you should generally be doing a mild check all around the entire vehicle. Engine oil, cooling system, transmission (feel it out by driving of course), electronics, brakes etc.
As far is g37 SPECIFIC items to look out for, only things I can say are premature rotor wear and the clutch which you can also find more info about on this site. Personally, I experienced the premature rotor warp shortly after I purchased my g37 but have had it now for about 5,000 miles and haven't had any other complaints.
Best of luck
Old Jul 7, 2014 | 10:00 PM
ang37's Avatar
ang37
Have it inspected by a professional. That's the best advice. Expecting to have new tires, breaks, rotors etc is unrealistic.
Old Jul 10, 2014 | 03:34 PM
GORILLA GAINS's Avatar
GORILLA GAINS
Check the rear sub-frame bushing for leakage, check the dip stick for low oil or rainbow colored oil.
Old Jul 16, 2014 | 11:01 AM
The1NickJohnson's Avatar
The1NickJohnson
I'd check the clutch.. Seen a lot of people have clutch issues at low mileage.
Old Jul 16, 2014 | 11:54 AM
Paceship's Avatar
Paceship
Rear brakes...these wear abnormally fast. Otherwise, drive it, buy it, enjoy it.
Old Jul 17, 2014 | 12:23 PM
SwissCheeseHead's Avatar
SwissCheeseHead
you guys are seriously focusing on wear items as a make or break deal on a used car??
First of all, it is "Brakes," not "breaks." Also, unless the worn parts are going to affect the drive-ability of the car, they won't get replaced.
Second, a modded are is not an abused car. There are plenty of stock cars that have been abused.
There are no big or major components on the car that can't be replaced relatively easily. The engine and transmission are known to be very stout, unless it was defective to begin with. If it's an MT, there may be a slight concern with the slave cylinder, but there is a heavy duty replacement for it. These things fail randomly and you won't be able to inspect it well enough prior to buying.
Side note, OP had only 1 post and I doubt we'll see this person again.
Old Jul 22, 2014 | 01:31 PM
rmfnla's Avatar
rmfnla
My advice would be to hold out for an S (as you've said you want) so you will get the upgraded steering, suspension and brakes...
slowbird
Aug 3, 2023 07:54 PM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
Broski28
Feb 26, 2016 12:26 PM
e92ry
Dec 31, 2015 08:02 PM
kevinmward
Aug 12, 2015 12:09 AM
