would they fix this??
Old Jan 3, 2011 | 01:43 AM
Skilled's Avatar
Skilled
hey guys and gals, i was wondering is there any bulletin on wind nosies for our windows. when i'm driving in the highway about 65 and up I start to hear wind noise whistling. maybe they would change out the window seal?
Old Jan 3, 2011 | 01:49 AM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
Try resetting the windows, sometimes they don't roll all the way up.
Old Jan 3, 2011 | 01:54 AM
Skilled's Avatar
Skilled
may i ask how do you reset them?
Old Jan 3, 2011 | 02:00 AM
RaulGCustom
SoCal Driven
Roll them down and hold the buttons for 8 seconds then roll them up and hold for 8 seconds. That should do it. Hope that helps.
Old Jan 3, 2011 | 02:07 AM
cruzmisl's Avatar
cruzmisl
They've done a few things on mine to fix whistling and water leaks.
The drivers side has actually never whistled on mine, but the passenger side has. They replaced the seals on both sides, but this didn't really do anything. It still whistles a bit.
Before replacing the seals, they stuffed some foam near the area of the whistle behind the seal, which forced it to push closer to the window and create a tighter seal. This worked a little better, but I believe part of the problem is a small area where the "triangle" piece (where the side mirrors set) closes onto the the seal. You'll see the edge of the window tuck into the seal a bit here, with a small area thats a bit open. I believe that this is the weakest area of the seal for water and air leakage.
I've looked at some G's and some have this area set tighter than others. I've seen some (like my dad's G), where the window almost completely tucks up into the seal here, while mine and a few others I've seen have maybe a centimeter gap.
They adjusted my drivers windows a bit by digging into the door and adjusting the range of motion when it closes--i think it's angled a hair differently than stock to create a better seal. I don't think I'd recommend doing this though because it makes the windows a hair noisier to use for some reason.
One problem with having them mess with your windows is that they'll likely break some of the door clips, which rattle like crazy. They'll cover replacing that but every time you take the door off and put it back on, one breaks. It's kind of ridiculous. I used to take the door panels off my E36 all the time and I never broke a clip once.
I don't know if this helps at all, but it's my experience with our doors/windows.
Old Jan 3, 2011 | 11:17 AM
Skilled's Avatar
Skilled
thank you guys i will try to reset but holding the button first then if that don't work for me, then i will go to dealer and see if they can do anything with the seals i appreciate it guys!
Victory
17
Oct 27, 2022 03:45 PM
delfinparis
Nov 16, 2015 02:26 PM
parkern
Oct 1, 2015 10:15 PM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
Chris_M
Sep 25, 2015 08:38 PM
