Winter Storage
Old Oct 29, 2008 | 05:47 PM
  #31
shumby's Avatar
shumby
ofcourse
Old Oct 29, 2008 | 05:57 PM
  #32
Graham's Avatar
Graham
I wouldn't do anything with your insurance policy. You can reduce mileage, but the only removeable coverages are comp and collision, so if someone runs into the garage where your parked car is, you have no coverage, if someone breaks in and vandalizies the car, you have no coverage. All your covered for is if you hit another driver, which the car isn't driving anyways. So why would you want to remove the only two coverages that may need to be used when a car is parked?
Old Oct 29, 2008 | 09:32 PM
  #33
CHI-TOWN G37's Avatar
CHI-TOWN G37
^^Yeah, and that putting-the-car-in-reverse thing may be trouble when it decides to leave your garage on its own
Old Oct 29, 2008 | 11:55 PM
  #34
Jim@Showstoppers's Avatar
Jim@Showstoppers
Every state is differnet, but in Minnesota we can put a storage insurance on the car. if anything happens to it while in the garage you are covered. It's kinda nice.
Old Oct 29, 2008 | 11:57 PM
  #35
Jim@Showstoppers
Originally Posted by oooLz
I've seen people do that. My question is, does putting it on jack stands adds unnecessary stress to the body? Can over inflating your tires and parking on carpet reduce flat spotting?
I don't really know to be honest. I'd rather put the weight on the frame of my car then on my suspension components.
Old Oct 30, 2008 | 12:03 AM
  #36
GiGGaplease's Avatar
GiGGaplease
cars are meant to be driven. so, why do you want to store away the g? its not like the g is a 500k car or anything.
Old Oct 30, 2008 | 10:19 AM
  #37
oooLz's Avatar
oooLz
^^^I have a winter beater that i'll be driving.
Winters here are pretty brutal. Lots of sand/salt on the streets to wear down the car.
Seeing how this winter goes, i might just slap on winters tires on the G and drive it next year all year. Having a race car in the winter is pretty savage though.
Old Nov 1, 2008 | 10:40 PM
  #38
Mayu's Avatar
Mayu
I have been looking this up too and from what I have read it appears you should jack up the car but from the axle joints so the supension is weigted. Reason being, suspension parts are not designed to hang but supprt weight. Jacking up the car (again from what I have read) is to prevent "flat" spots on the tires and has little to no bearing on anything else. I think this may be great if you were storing for a few years.
I will pump up the tires to 45PSI snd deflate them before driving. The battery leading to electrolysis kind of scares me... I want to take it out but am not sure if I will loose things stored in the seat memory, homelink or HD?
Old Nov 3, 2008 | 09:13 AM
  #39
oooLz's Avatar
oooLz
my plan is to store it in the garage for the winter. i plan to fire up the engine for a couple mins once or twice a week to keep it in shape. any comments?
Old Nov 3, 2008 | 09:24 AM
  #40
CHI-TOWN G37
^Yes, don't sit in the garage when the car is running
Really, you need to get it out and drive it and properly warm up everything and move the components. The engine really needs to be run up to full temp and not just started for a couple minutes and then shut down. This can cause excess moisture to be trapped in your exhaust and other areas and cause more harm than good. Just drive it around the block about 40 times while waving to your neighbors if you are scared to take it away from home too far
Old Nov 4, 2008 | 08:10 AM
  #41
Jim@Showstoppers
Do not start up our car, all you create in condensation inside the motor from heating and cooling it down. It's tough, but just remove your battery and let that baby sit all winter long.
Old Nov 4, 2008 | 08:12 AM
  #42
Jim@Showstoppers
You will lose your seat memory, I'm not sure about homelink. I'm 90% sure you will still lose that when your battery freezes and dies. You are much better off taking the battery out and bringing it inside.
I put my car on jacks, then use blocks to load my suspension so it's not just hanging there
indyn
Nov 17, 2015 06:48 PM
Dillybar12
Nov 1, 2015 07:23 PM
ck1109
Oct 15, 2015 11:06 PM
rk325
Oct 13, 2015 01:51 PM
bobtaz13
Oct 1, 2015 01:39 PM
