Car beeping every 5 secs after completely locking
Old Oct 17, 2020 | 02:28 AM
Edyy00's Avatar
Edyy00
Today, it's the first time my g37 starts to beep continiouly after locking the car, noting that everything is closed and the lights are off etc..
I hear 2 quick beeps every 5 sec for at least 5 minutes, then it stops.
From my findings, this may have happened due to 2 things:
either because i ve changed the battery, or because a have 2 reminders of oil change and filter.
anyone familiar with this?
Old Oct 17, 2020 | 01:34 PM
iCrap's Avatar
iCrap
Do you have 2 keys? I think it does this if you lock it but there is still another key inside. I had that happen for a while until i realized the other key fell under the seat.
Old Oct 17, 2020 | 02:07 PM
Tucsontripleb's Avatar
Tucsontripleb
Try this....
https://www.myg37.com/forums/g37-con...placement.html
Old Oct 17, 2020 | 06:23 PM
stugots81787's Avatar
stugots81787
Cycle the top. Open and close the convertible top it should stop. Did you pull the battery?
Old Oct 31, 2020 | 09:46 AM
3BOSH's Avatar
3BOSH
what the last guy said
can we get an admin to pin it
idk who is and how to even find out
Old Oct 31, 2020 | 08:31 PM
Tucsontripleb
What the "last guy said" is also what my earlier link says. I was trying to show that a simple search of the forum using the exact words the OP used will generate the answer in a matter of seconds.
Old Nov 3, 2020 | 01:05 AM
3BOSH's Avatar
3BOSH
u r 100% right, but some of the users might be old or not good with computers / forums in general
I still find difficulties in a lot of stuff
a sticky post of either searching or actual FAQ is not a bad idea as all other forums for most cars and most anything usually do it
Old Feb 25, 2023 | 06:57 AM
Margaret45's Avatar
Margaret45
If you're looking for automobile registration information for licence plate finder, please visit click here We can look up your vehicle and provide you with a wealth of information. For example, we can tell you if your vehicle has a vin number or a service history.
Old Feb 26, 2023 | 09:23 AM
Jeledoux's Avatar
Jeledoux
Cycle the Top
I've run into this exact same problem and cycling the convertible top solved it.
gimmeshelter67
Jan 23, 2025 04:55 PM
Chekov
May 18, 2016 11:47 PM
enronforme
Apr 9, 2013 02:13 PM
Frank
Oct 18, 2009 12:12 AM
