Rubber bumper on convertible arm
Old Jun 7, 2022 | 10:05 PM
kiseliok's Avatar
kiseliok
G37 Community Team
That's correct. Clean up the leftovers inside the cups and just wedge in the new ones in a twisting motion. They'll stay in there.
Old Jun 7, 2022 | 10:29 PM
haleakalag's Avatar
haleakalag
Thanks much
Thanks much.
Old Sep 10, 2022 | 03:57 PM
RANDY350Z's Avatar
RANDY350Z
Originally Posted by paul prachyl
these worked great!! Thanks!!
Old Sep 18, 2022 | 09:42 PM
MarkEJohnson66's Avatar
MarkEJohnson66
Convertible rubber stopper-bumper
Originally Posted by Paul Prachyl
I just installed these, too. The old reddish ones were crumbling apart, and they were easy enough to pry out with my fingers. These replacements were a good fit, just requiring a flat screwdriver to help squish the larger end down into the convertible mechanism's metal "socket."
I went right back and ordered two more to have onhand in case they need to be replaced again. (We have hot, dry summers in SoCal that I imagine are demanding on these rubber parts.)
Old Aug 15, 2023 | 02:12 PM
RogerSmith's Avatar
RogerSmith
How's the rubber bumper holding up nearly a year later?
Have you had a need to replace again?
Any residue markings left on the roof and/or some other unforseen problem?
Thanks.
Old Aug 15, 2023 | 02:24 PM
Tbchalmers's Avatar
Tbchalmers
Thanks.
after over a year the HomeDepot solution has held up great. Still looks new!
Old Aug 15, 2023 | 04:25 PM
mjp0n3_'s Avatar
mjp0n3_
My G37 also has disintegrating rubber bumpers (the ones on the trunk floor) and I'm wondering if there's an alternative to the OEM product (97039-JJ50A) which are currently 163 a piece.
Old Aug 19, 2023 | 10:57 PM
MarkEJohnson66
Working well. No residue, no replacement needed. I live in SoCal so we get plenty of heat that can be a challenge to polymers. I'm very pleased.
Old Sep 24, 2023 | 09:47 PM
petemo94's Avatar
petemo94
Curious if anyone knows what problem occurs in the roof mechanism if these things deteriorate?
One of mine has deteriorated and just trying to see if it causes a rattle or something. Not sure how these come into play with the roof opening/closing
Old Sep 29, 2023 | 09:33 PM
kiseliok's Avatar
kiseliok
G37 Community Team
These seem to support the trunk when it swings back during the roof operation.
I'm not sure how these would deteriorate from driving, other than normal wear and tear from the external elements.
Old Aug 3, 2025 | 07:59 PM
olin's Avatar
olin
The rubber stopper will work for the stops that are in the metal cans. There is another bumper on a nearby convertible arm. It seems to be mounter on a flat plate. any solutions for this>
Old Aug 4, 2025 | 09:15 AM
ILM-NC G37S's Avatar
ILM-NC G37S
I will be frank, as far as Infiniti is concerned anything concerning those flipper arms usually mean that the whole arm gets replaced as a unit. In other words, you might have to come up with a backyard solution of your own.
Can you provide a picture of some sort indicating what you are needing?
Old Aug 22, 2025 | 08:03 PM
bnovinski's Avatar
bnovinski
I am thinking - that for the price and the scarcity of these - that it may be relatively easier to get a block of rubber and cut the shape out (it is actually not overly complex) or make a mold and use two part firm-setting silicone. I need to look into this further, but this has been on my mind to get duplicates before they deteriorated.
udannefitz
G37 Convertible
Aug 4, 2025 05:58 PM
Dough1397
Jun 25, 2019 01:10 AM
R1cky
May 21, 2016 10:11 AM
Redfire32
Aug 11, 2015 09:05 AM
NYG37S
Feb 8, 2012 07:26 AM
