Airbag Occupancy Sensor emulator install in Vert seat
Old Sep 20, 2025 | 03:20 PM
  #31
Guy Menard's Avatar
Guy Menard
I have an Airbag360 installed on mine for over 5 years now and…Never had problems with it!
seat work fine, the only thing happened is, if there’s no passenger with seatbelt buckle up, the red airbag light in the cluster stay on.
otherwise, it works flawlessly as it supposed to to.
Old Sep 21, 2025 | 01:16 PM
  #32
rfurball's Avatar
rfurball
Works
Installed mine 3 yrs ago now and no problems with seat functionality. Rest of the car has been really good also - no probs at 85k now.
Old Sep 22, 2025 | 09:29 AM
  #33
tinker's Avatar
tinker
Obd killer
I wonder if there are any OBD2 Killer plugs that block the fault code automatically?
Old Jan 27, 2026 | 11:01 AM
  #34
pburger's Avatar
pburger
I posted to this thread back in 2018 - almost 8 years ago. Back then I had the flashing SRS light and the dealer replaced the passenger seat bottom under warranty(it falls under the powertrain warranty). Well, it got very cold the other day, and the flashing light came on again. I'm well out of warranty now, so I was planning on installing an emulator/bypass. I did the reset procedure (on, wait for light to flash, then off and back on immediately, and repeat 3-4 times - I did it 5 times). The light is off!😃 Hopefully this was a one-off glitch due to the low temperatures. 🙏🏻🤞🏻. Time will tell. My 2013 G37 vert is still going strong, and I'd like to keep it that way. This is by far the best car I've ever owned.
Old Mar 2, 2026 | 09:42 AM
  #35
pburger's Avatar
pburger
Follow-up. After a few weeks, the SRS light came back on. one long flash, 5 short flashes, which I believe is the occupancy sensor. It won't reset anymore. I ordered the occupancy sensor emulator about a week ago. It should be arriving soon. It's a shame you can't just replace the sensor itself.
tnthudson
G37 Convertible
Apr 19, 2022 11:39 AM
Lucky13S
Jul 31, 2018 12:06 AM
Jonesmeister11
Jun 21, 2017 11:53 AM
Jonesmeister11
General Tech Questions
May 18, 2017 02:21 AM
