Newbie with flipper trouble
Old Aug 5, 2021 | 09:48 PM
  #61
atstewart1's Avatar
atstewart1
Salvage yard
Have you tried a salvage yard?
Originally Posted by Lake,an
I need help on finding just the flipper doors. I had the partial shelf motor motor go out and i live 250 miles from the nearest Infiniti dealer. I took it to a Nissan dealer near by. Well they ended up breaking both flipper doors. They said they were already broken but they were not. I need both flipper doors with the mounting plates. I have called all over and can not get a part number. Has anyone just purchased the doors only or does it only come with the complete partial shelf side assembly. I have tried ebay with no luck.
Old Aug 5, 2021 | 10:31 PM
  #62
ILM-NC G37S's Avatar
ILM-NC G37S
Gotcha. You can get just the trim panel (Board- Rear Side Finisher), this:
I found the part numbers for the Side Finisher(s):
LEFT Side: 799A5-JJ50A, -JJ50B, or -JJ50C.
Right Side: 799A4-JJ50A, -JJ50B, or -JJ50C.
Discount Infiniti Parts has the price listed at $178 each.
I strongly suggest you contact them, provide your VIN, and have them verify before you buy!
You can not order just the base as that appears to be permanently attached to the arm. That is only available as a whole assembly (for $875):
Your best bet would be to start checking junkyards if you need the base/arm assembly.
Old Aug 6, 2021 | 05:25 PM
  #63
Lake,an's Avatar
Lake,an
Thank You so much for spending the time to find this !!!! Yes the base plate has a 14mm or 12mm nut that holds it on.I live in Lake Havasu,AZ so i will try a junkyard in Vegas or Phoenix which both are over a 3 hour drive. I know there are not many G37 convertibles out there so it might be a challenge. So is the 799MA the part number for the complete base/arm unit and the flapper is separate. I will post some pics of what i have but it's everything but the base and flapper. When i open and close the top the arm works fine. Thx Again
Old Aug 6, 2021 | 05:58 PM
  #64
ILM-NC G37S
In the diagram pictured above, the classification code (not part number) 79912MA refers to the whole linkage (arm/ base). The actual part numbers for the linkage are:
(L) 79913-JJ50B, and
(R) 79912-JJ50B.
Both are listed at $875 each at Discount Infiniti Parts.
There are several online junkyards that you can make enquiries with. Sites such as car-part.com, partshotlines.com, and hollanderparts.com all have "parts request forms" that might help you.
While these parts come up on eBay from time to time, often they are way overpriced for what they are.
Old Aug 8, 2021 | 01:33 PM
  #65
pol's Avatar
pol
Please watch this video if you can DIY - flippers
Old Sep 13, 2021 | 09:53 PM
  #66
MichInfiniti's Avatar
MichInfiniti
Having problems disconnecting the flipper elec. harness's. Got the big white one unclipped, but can't figure out how to disconnect the smaller brown one. Any help appreciated.
Old Nov 9, 2021 | 08:46 PM
  #67
rem1957's Avatar
rem1957
I just finished replacing this linkage assembly on my 2014 Q60. I bought it from Infiniti Wholesale Direct for $829.56 + tax and shipping, $924 total.It took a few hours, but wasn't too difficult. Thanks for all the pictures and instruction by the previous posters. Some thoughts on the process:
1) Put down a blanket or other material across the trunk lid. and over the linkage mechanisms at the side of the trunk, because if you drop a screw down there, it's a goner.
2) The recessed bolt has a threaded washer on the inside of the hole. If you use a screwdriver or a trim fastener removal tool to pull down on the screw head it will bind the washer enough that you can un-thread it.To re-instal, I used some cellophane tape to tape the washer to the top side of the linkage frame to keep it in place until the bolt was in.
3) Now that the assembly is in place, the finisher isn't quite in the right place. It's tipped a little so that the front edge is elevated and the rear is dipped a little. Trying to figure out how to adjust the alignment. Any ideas?
Old Nov 9, 2021 | 10:06 PM
  #68
JJJ's Avatar
JJJ
I think I had a similar situation today. I just kept tightening and it evened out.
Old Nov 9, 2021 | 10:11 PM
  #69
JJJ's Avatar
JJJ
HELP!!! I replaced the left and right gears on the flipper unit following the instruction son this post. After everything got replaced and the flipper units got reinstalled I tried to close the top. The roof made it into the closed position but the trunk got stuck in the open position. Now the top won't go back to the open position or complete the closing process. On the bright side the flipper units did move to the closed position. Any ideas what might be wrong???
Old Nov 10, 2021 | 06:24 PM
  #70
dranik182's Avatar
dranik182
Would you sell your old parts? If so could you please message me at +1 (323) 348-9961
Old Nov 11, 2021 | 10:33 AM
  #71
kiseliok's Avatar
kiseliok
G37 Community Team
Your parcel shelf should not be laying on the trunk floor - something must've gotten tangled during the open / closing process. It should be either up and flat (roof open) or down and vertical (roof closed). That's where I'd look first.
Old Jan 31, 2023 | 01:18 PM
  #72
steven1's Avatar
steven1
Flipper panel gears
Good morning to you, thank you for letting me join your site. I have a 2014 Q60 Hardtop convertible. Would you please help me by providing a way to purchase the replacement gears (left and right side) in the Flipper panels.
Respectfully
Steven1
stevyoun@hotmail.com
Old Jan 31, 2023 | 02:53 PM
  #73
dranik182's Avatar
dranik182
Respectfully
Steven1
Hello. I'm the one who make those gears. Please check my eBay listings:
https://www.ebay.com/itm/255471419996
https://www.ebay.com/itm/255814130968
Or you can contact me directly for ''no tax price" dranik182@gmail.com
Old Jan 31, 2023 | 05:06 PM
  #74
atstewart1's Avatar
atstewart1
Driver side metal gear for flipper for sale $175
I bought both gears from Guy even though only the passenger side needed to be replaced. I sold my 2013 G37 and have no use for the driver's side gear. I am willing to sell it for $175 plus shipping. If interested email me at at@atstewart.com with the subject G37 GEAR
Old Apr 22, 2023 | 02:25 PM
  #75
HH94's Avatar
HH94
Guy menard!!!!
Guy menard is amazing.
Dude sent me gears and additional emails guiding me through flipper reparis amongst other things.
Super great guy!!!!!
