"beep beep" sound from the backseat
Old Feb 26, 2013 | 07:10 PM
weird60625's Avatar
weird60625
i recently heard a sound " beep beep" back on the driver side, this beep sound is gone when the car on running buit sometimes when i locked the door check trunk locked and everything i still hear the beep beep sound , press the LOCK on FOb key the beep sound is gone ... wonder why is that ?
Old Feb 26, 2013 | 07:27 PM
bschurr's Avatar
bschurr
try "resetting" the flap in the trunk that needs to be "locked in" before you lower the roof by putting in position and taking it out of position a few times. If that doesnt fix it, lower & then raise the roof and the beeping sound should be gone. Dont ask me why the car does this but mine did the same thing a couple of weeks ago when I exercised it after a few weeks of winter hibernation.
Good luck!
Old Feb 27, 2013 | 03:33 PM
weird60625's Avatar
weird60625
thanks bschurr, your mentioned about the roof does makes sense to me since i noticed the beep sound after bring it back from the dealer for the roof raffle noise fixing.
so i just need to top down and top up will fix the issue ?
Old Mar 2, 2013 | 07:51 PM
demarcom's Avatar
demarcom
I had this strange beeping noise and it's due to the top not being closed 100%. go through the cycle of opening and closing the roof and you should be good. Just make sure you keep your finger on the close button for a second or 2 after is says it's closed.
Old Mar 2, 2013 | 10:21 PM
neuzpeed's Avatar
neuzpeed
I had this happen to me after I need to jump my battery. It's the convertible roof and it needs to be reset by the dealership.
Old Jan 9, 2017 | 07:06 PM
Autocutter's Avatar
Autocutter
I just had this happen to my vert after I had to jump the car. No warning lights showed in the dash board. I opened & closed both doors to no avail, but when i opened and closed the trunk that strange beeping stopped. I'll be replacing the battery tomorrow is there anything I have to reset?
Old Jan 11, 2017 | 09:32 AM
kiseliok's Avatar
kiseliok
G37 Community Team
No. It'll go away once you cycle the roof.
parkern
Oct 5, 2015 12:12 PM
G37sPhoton
Oct 4, 2015 11:08 PM
parkern
Oct 1, 2015 10:15 PM
MrRiv
Sep 29, 2015 04:59 PM
