how do i get a spare tire?
Old Apr 7, 2014 | 09:01 PM
  #46
miketyler's Avatar
miketyler
Thanks for the explanation. Its just my luck, mine has the repair kit. If I were to get one of these space savers is its placement in the trunk area critical? Is there a place for a jack stashed back in some compartment there in the back?
Old Apr 10, 2014 | 05:52 PM
  #47
ATLcple's Avatar
ATLcple
Simply, the spare tire fits in the spare-tire-space under the trunk floor of EVERY G37 built. They did not engineer the trunk differently for the two distinct options (the spare tire vs the tire repair kit).
The KIT comes with a flat repair canister and an electric compressor (that plugs into your 12v receptacle inside the car). The spare tire DOES come with a jack (of course), and it stows behind a panel at the very rear of the trunk.
Because the spare tire kit deletes the compressor and all the other repair gear...it is only a $180 option at time of purchase. If you try to purchase the spare tire and everything that comes with it AFTER initially buying the car without one, it will cost you over $500...I have read.
Old Apr 13, 2014 | 08:15 AM
  #48
miketyler's Avatar
miketyler
Thanks ATL - appreciate the detailed explanation.
Old Apr 13, 2014 | 08:52 AM
  #49
miketyler's Avatar
miketyler
And just for illustrative purposes, is this what an OEM convertible mini spare looks like? This one looks aftermarket to me. This one is for sale in parts section.
Old Apr 16, 2014 | 07:50 AM
  #50
ATLcple's Avatar
ATLcple
Mike,
Yes, I think that's the factory wheel. I don't remember if mine is black (vs silver), but the spare rim IS a 5-spoke, split design. I would have to remove my spare to be 100% sure, since the spare rests in position with the OTHER side facing up in the trunk. There also is a small, round, Styrofoam 'tool-holder' that's rests 'in the wheel' as it sits facing down in the trunk space. This tool holder holds a pry-bar, extra lugs (if you have wheel-locks installed, some "I-bolt" (don't know what that's used for!), and the jack-turn-handle (NOT the jack itself...the scissor-jack is behind a panel at the back of the trunk, as previously mentioned).
On a final note...the rim, on the backside of one of the spokes, has the word "NISSAN" stamped on it. The regular wheels are ENIKEI sourced, but Nissan obviously makes the spare in this case. Is all this 'clear as mud' now? ...or have I generated more questions?
On a final note, I really don't think many people take the time and effort to 'purchase separately' the entire spare tire kit. I think most folks are happy with the repair kit and the readily-available Roadside Assistance programs out there. I think there is not enough "return on investment" in this case. My car DOES have the spare, but I would have bought it anyway if it didn't. I hope I never use the spare, lol.
Old May 24, 2014 | 12:16 AM
  #51
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
hmmmmmmmmmm, I want more space in my trunk for a tank eventually for an air ride setup.
ATLcple can you post a pic of your trunk setup with the spare?
bri
Nov 23, 2015 11:35 PM
Juancgn33
Sep 10, 2015 07:25 PM
mmnjtwa
Sep 7, 2015 02:27 PM
allen738
Sep 6, 2015 09:36 PM
Gio37
Sep 6, 2015 02:36 PM
