VDC stays on randomly
Old Dec 21, 2020 | 03:52 PM
operat0r's Avatar
operat0r
Thumbs up VDC stays on randomly
So I been having this issue for a long time with the Vehicle Dynamic Control, VDC light… Maybe if I can check the wheel sensors some how without taking them off or whatever ?
· Performed a ECU reset
· My brake fluid and brake pads are fine. I still have this issue.
· Tire pressure is good
· Fuses next to battery are good too ( VDC ABS and whatever the other one in there is )
· No other fault codes
· No other issues I can see
· I have Advanced LT is a plugin for Torque Pro
· My manuals https://rmccurdy.com/.scripts/downloaded/Q40/
· Past year I had to unscrew the break light switch to make it engage because I think when I was in a fender bender it got nocked down or something/somebody messed with it so when I lifted off the break it would think the break was still engaged and cruise control was not working. I fixed that. I did notice another switch next to the switch I fixed for cruise control not sure what that is for or if it needs to be adjusted.
· Its been doing it for a LONG time. I think even before I blew 3 fuses plugging in harness the wrong order when I made myself a AUX by hijacking the HD Radio input. https://www.myg37.com/forums/audio-v...rap-audio.html
· I don’t drive it hardly at all my wife drives and I work from home most the time 3-5 days a week
Torque Logs: https://rmccurdy.com/.scripts/downlo...0_12-24-02.csv
12 : 40 break light came on for a second while quickly accelerating /turning
12 : 44 VDC light came on for a second while quickly accelerating /turning
12 : 46 Break light shortly followed by VDC light won’t turn off after quickly accelerating/turning
12 : 47 : Break light on/off and VDC light still on quickly accelerating/turning
12 : 49 Break light on/off and VDC light still on quickly accelerating/turning
Also I ripped all of nicoclub.com for you yall as a mirror feel free to share URL/Script 😊
Script : https://rmccurdy.com/.scripts/downlo....com.ripp.bash
Mirror/Archive : https://rmccurdy.com/.scripts/downloaded/nicoclub.com/
Old Dec 24, 2020 | 08:07 AM
SonicVQ's Avatar
SonicVQ
You may want to scan the ABS module for codes.
The least expensive way I know is OBD Fusion ($7) with the $14 Enhanced diagnostic add-on.
What is nice about this add-on, is it allows you to scan ALL the modules in the car AND if they have PIDs, you can view them in real time.
Here is a video on a G37 to show what is looks like
Old Mar 29, 2021 | 11:38 AM
operat0r's Avatar
operat0r
https://youtu.be/YTnXu9JtmhY
Herm looks like I did it right? Didn't see any fault codes. Or am I looking for ABS specific PIDs ?
Old Mar 29, 2021 | 12:06 PM
SonicVQ's Avatar
SonicVQ
Torque Pro with the Infiniti plug-ins ONLY show enhanced ECU PIDs/data, so that isn't going to help with ABS/VDC issues.
OBDFusion with the enhanced diagnostics can scan, clear and show LIVE data like individual wheel speeds and 40+ other ABS module related items.
CleanAsFuhh
Jan 8, 2025 03:12 PM
SammyD1
Aug 10, 2020 08:17 AM
nicaland
General Tech Questions
Feb 3, 2020 06:08 PM
marcopolo15
Mar 29, 2012 12:43 PM
Chapinb
Jan 28, 2010 10:48 PM
