Help Car Stalling in Drive and in Reverse
Ouch! Damn...
If you are not able to pull any codes/diagnose any further, I would take the car to a reputable transmission shop and go from there. Remember, if the clutch piston inside the torque converter is not releasing, either the piston/valve is physically stuck or, possible, the solenoid is stuck open. Almost impossible to say at this point.
At the very least you should at least plan on changing the ATF- never know, this could solve your issue especially if "gunk" has built up. This is DIY might help: CHANGING G37 ATF DIY
Called Infiniti and got the TCM Valve Body part number for my VIN.
It's a $1500 part. I further diagnosed my car (and had to drive it home) and I'm pretty dang sure it's the torque converter clutch solenoid. So in order for me to replace I basically have to buy it from Infiniti, or find another G37 that's being parted out with the same exact part. Even after I replaced it, I would still need to take it to Infiniti to register the TCM to the new VIN.....
Basically it looks like this is a $2-3000 job minimum.
I haven't really decided what to do next.... I still owe like 8k on this car...
Samesiis , hoping it's in the converter for me.
So I'm experiencing this*exact* same issue. ! Everything the same. Never stalled in park I must add though. But the same symptoms when coming to a full stop where it wants to keep driving. I feel like I need to press in a clutch like in a manual car! I have gone ahead and googled enough in the last few weeks to give me many headaches and I have ordered in an upgraded 500whp TQ converter from Level10. My car is tuned I should also add. Basic bolt ons as well.
Over the last few months the car has steadily wanted to lurch forward harder and harder when I'm putting it in drive and setting off for a drive I feel like this was my sign that it was on its way out.
The problem is intermittent. Certainly not every light at all. Maybe only every 15th light for me. And sometimes never at all for a short drive. But there's times where I'll get all the way home and it'll do it going into reverse to park the car. Almost a perfect drive. Sigh. Lol
Anyway a trans shop looked at the car the last two days and says the car is fine. There's no issues no codes related etc and they couldn't reproduce the problem. Although the issue occurred on the way TO AND FROM the shop for me!!!
Long story short I took my car home and I phoned the dealership. I want peace of mind going where they have the tools to do it all and the service manuals to point them in the right direction.
Not a cheap job, I'm sure but with a little luck it's just the Lockup Inside the TQ converter itself that is the issue , and not the actual solenoid itself.
Have never changed the atf I will also add. Have asked at the dealer and have been told it doesn't need it for a while yet. I'm at 120,000kms (70k miles?)
Fingers crossed the dealer throws this new upgraded TQ converter in and new fluids and she is as good as new again ! Appx 2 weeks will know more and update *
I hope everyone else has luck finding the issues with their G.
Jp
*Edit* The dealer replaced my oem torque converter with the bulletproof 500hp one from Level10 and the car drives beautifully. They also did fresh fluids with the change so I'm not ruling out fluid level or dirty fluid, that may have contributed to my issue but regardless the new TQ converter set me right on my way. 10/10 again !
Edit #2 !
Less than 2500km after the upgraded level 10 torque converter install at the dealership I'm experiencing really bad knocking when I'm coming to a stop or when stopped in drive and reverse. The same style issue as before ! But not locking up like before , just this sack of hammers sound banging around under the car. So I brought it to the dealership. Hoping that there was some defective install as it was still under a year from install and the dealership usually will cover costs if it's a labour issue. Or if it's an OEM part they'll replace that. In my case. I paid for them to diagnose the car, they pointed to the Torque Converter. ( Which they had just installed 8/10 months prior. prior.
Seemed very unlikely to me but whatever. They removed the TQ converter , I sent it back to the folks at Level10 Transmission and they took it apart and diagnosed it with a damaged damper. Which would explain the sounds. Etc.
SO.
Level 10 shipped me a new/rebuilt TQ converter at my shipping expense both ways. And the dealership slapped it in when it finished it's week and a half long turnaround. Since then it's been smooth sailing but I drive it a bit more gingerly now than before.
$1800Cdn + TQ Cnv. Cost the first time
$2300 + Shipping the Parts across 2 countries. Second Time.
This thing needs any more than an oil change from now on and I'm burning it.
My 2010 G37 Journey Sedan 7at is having some major issues.
As of right now it will idle in Park and in Neutral, but when I put it in reverse or into drive it will stall the motor. I can get it into gear only if I rev to around 3k rpm or higher and then slam it into gear.
Once I'm driving it, it will often stall at stop lights and stop signs for the same reason. When it stalls and I'm stopping it feels like the transmission doesn't want to disconnect and it stays engaged bogging the engine out.
I personally was thinking torque converter could be stuck locking up. However a couple times it would start in Park and then stall out immediately too, so someone said it could just be that my plugs are over-gapped because of the spirited driving I was doing before this issue.
Any thoughts? Btw once it's up and running it shifts I to all 7 gears without problems, and there's no check engine light. Any help would be appreciated.
My plan is to change the plugs this week, if that doesn't fix it I'm going to get a torque converter and drop the tranny myself, unless y'all have better ideas?
hey. it's your transmission/torque converter. can't say which one for sure. my 13 sedan started doing the same thing after a hard pull from a stop. i had changed the trans oil a few months before that. @ 95k miles. i did drive it around a couple of weeks because it was intermittent. it finally started stalling all the time so i swapped it with a used trans/torque conv. myself. problem solved. could be just the torque converter. thing is, when they fail, it produces metal shavings that contaminates your actual transmission. i think that's what happened to my trans. it had metal shavings everywhere inside, although it was shifting fine until the very end. i never got a check engine light BTW.
I think I'm having this issue right now. A cracked hose ran out all my transmission fluid. And I never noticed it until after driving it for an additional 15 miles. You mentioned it was shifting fine until the very end, do you mean the transmission eventually failed due to all the metal shavings produced by a failed torque converter? I debated on just swapping whole transmission out for the VR30
I Have the same problem but with Codes
Hey what transmission did you swap your old one with? I have a 2014 Q50 and im about to put a 2011 g37 transmission in it. They are the same exact transmission but they are different years, you think itll work?
Hey did you ever fix the problem?
skimbrell11
Jan 18, 2023 03:04 PM
MaxdOut
45
Jul 30, 2009 06:17 PM
