What could cause the RPM to bog down only around 1k?
Hello. I have a 2007 G35x with an UpRev tune. When the engine is engaged (either Reverse or Drive) the car revs up to around 1k, bogs and feels like it's going to stall for a moment, then picks it self back up to where it left off. The entire rest of the RPM band does not have this issue. It also seems more apparent under light throttle, not as obvious under quick/heavy throttle. There is also a mild misfire sound happening during idle. No codes present.
All of the reset procedures have been carried out and I've carefully cleaned the TB's. One thing to note is that my throttle bodies do make a rattling sound when tapped on, if that's of any help. I'm leaning towards them or possibly a bad coil pack... What do the kind folk of the forum make of this? Any data I should be logging in particular? Any and all advice is appreciated.
Telcoman
G-MENTED
12-04-2017 07:35 PM
xpcgamer
14
02-02-2016 11:46 AM
