Help rpm jumps down Help!
hey,
i just got my ark exhuast installed today, and i encountered a weird rpm promblem, it doesnt happen all the time, but it happens like 3-4 times a day,
the rpm jumps down 2 slits before 0, and it feels like the car is going to shut off, but it jumps right back up under 1, and this happens on Idle only!, when driving its fine, do you think its the exhuast causing the promblem? or do i need to clean my throttle bodies? its weird because it never did that before i installed the exhaust.
thanks for the help
thanks for the help
HKS filters? the green foam stuff? Those are not meant for street daily driving filtration. Take them off now and install a proper dry type filter. Those are meant strictly for circuit racing where maximum airflow is needed and they are there simply to prevent large debris from getting sucked into turbos/engines.
they're still the same material and personally I wouldn't use them. I had a really old article wriiten that compares filter media types from different manufactureres. I don't have it any more, anyhow they HKS green foam stuff was the worst. You'd be surprised at the junk they found going through the filter. The AEM dryflow had both the best filtration as well as the best flow characteristics.
Wow not to say you are wrong , but Ive read pages and pages of nothing but great reviews, they are non oiled filters that are reusable and suppose to be a great substitute for stocks, I've had for like 10-15,000 miles and they still look pretty clean .
Originally Posted by BlkHR37S
Either way the car feels more powerful and more responsive w these rather than both my previous JWT and injen SRi...
I found the test online. It was done by a Japanese magazine.
http://mkiv.com/techarticles/filters_test/2/index.html
Check out these threads. Found them after a brief google search.
HKS filters and turbo damage - The mkiv Supra Owners Club
http://forums.evolutionm.net/dynofla...er-enough.html
What does it tell you if you have driven 15K mikes with those filters and they are still clean? Is there no dust and dirt in your environment? And if there is, where do you think it is going if it's not getting trapped in your filtration media?
