Lean fire
Old Apr 19, 2018 | 07:16 PM
doveguy1's Avatar
doveguy1
Lean fire
I have a check engine light on. Took to auto the code was lean fire bank two. I cleaned the MAF no change. The car has 140k miles.
three question
wich bank is two?
common problem.
auto zone said possible faulty Ignition How would that cause a lean fire I would think that would be rich.
Any thoughts
Old Apr 19, 2018 | 07:28 PM
soundkillr's Avatar
soundkillr
The afr (or some call oxygen sensors upstream position 1) can be bad and causing a lean condition. I know on mine the afrs went bad and the car wouldnt go lower than 13.4 floored, which is too lean. Replaced them and immediately went to high 11s floored, which is were you want to be. The lean condition will also lead to misfires...
Old Apr 20, 2018 | 07:47 AM
slartibartfast's Avatar
slartibartfast
Bank 2 is the driver's side. Your problem has been discussed in threads in the Tech/Engine & Drivetrain forum.
604gz
May 14, 2015 06:06 PM
pkim4
Nov 3, 2014 10:54 PM
ChinkyChoy
Intake and Exhaust
Mar 24, 2014 05:15 PM
Modi-G37
Apr 19, 2012 01:42 PM
G37Sam
45
Jan 13, 2010 07:11 PM
