Help Leaking Fuel G37
Old Jan 27, 2018 | 03:28 PM
Fazz73jr's Avatar
Fazz73jr
Exclamation Help Leaking Fuel G37
leaking fuel from this. I want to say its a fuel pressure regulator but I'm not sure. looking it up on rockauto only thing I find is fuel pressure damper. Whats this called and where can I get one? Thanks!
Old Jan 27, 2018 | 03:45 PM
Sangpham's Avatar
Sangpham
Its name Fuel damper. Part No.: 22675-JK20Bhttps://www.myg37.com/forums/d-i-y-i...el-damper.html
Old Jan 27, 2018 | 04:09 PM
JSolo's Avatar
JSolo
Just say no!!!!!
What year is your vehicle, miles? Looks like the part comes with a hose attached w/ fuel line fitting. Wonder how much of a pain it is to remove/replace.
Old Jan 27, 2018 | 04:44 PM
Fazz73jr's Avatar
Fazz73jr
Thank You! Sangpham
Old Jan 27, 2018 | 04:47 PM
Fazz73jr's Avatar
Fazz73jr
Its an 08, about 150k.. ill be finding out real quick how much of a pain it is. lol
Old Jan 27, 2018 | 05:11 PM
JSolo's Avatar
JSolo
Just say no!!!!!
I haven't looked on my own car, but not possible to just replace the part at the hose connection?
Here's what comes to mind. If the above is not possible, then you'll likely be moving/disturbing other hoses in the process, possibly breaking other parts as plastic is likely brittle now.
Old Jan 27, 2018 | 06:44 PM
PNW_IPL's Avatar
PNW_IPL
maybe but part is broke and needs fixing. So gotta break other shizz to fix damper so be it...
Old Jan 30, 2018 | 11:11 AM
ANMVQ's Avatar
ANMVQ
There is a rubber o-ring in there that might need to be replaced? I'ts hard to think the metal housing has a hole in it
Old Jan 30, 2018 | 11:35 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Sometimes a search works wonders...
Old Feb 4, 2018 | 04:08 PM
g37-lover's Avatar
g37-lover
Anyone know if the whole line needs to be replaced or if you can somehow pull of the dome shaped damper at the end?
kirDani254
Dec 14, 2017 01:45 PM
Dan08g37s
Oct 26, 2017 03:49 PM
aakhan1
G37 Convertible
19
Feb 26, 2016 10:07 PM
daren_ipl
Apr 27, 2013 08:15 PM
WRX_to_G37
Oct 2, 2011 09:15 PM
