Help Coolant leak
Old Jan 13, 2018 | 07:13 PM
Dillons VQ37's Avatar
Dillons VQ37
Coolant leak
I have a coolant leak coming from the bottom of this coolant fill neck, does anyone by hanged know the part number? Tried to google it but can't find it.
Old Jan 13, 2018 | 07:24 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Maybe I'm blind but I don't see it. Can you circle in red where its leaking?
What I do see is the cap is not fully on. I believe when it is, the two ears are parallel to the engine.
Look at ~1m20s time
Old Jan 13, 2018 | 07:36 PM
Dillons VQ37
It's leaking from the bottom of the elbow
Old Jan 13, 2018 | 11:56 PM
slartibartfast's Avatar
slartibartfast
Which year? I don't see a capped neck in the parts drawings here:
https://www.discountinfinitiparts.co...iagram=3846035
I selected 2013 Base at random.
Old Jan 14, 2018 | 12:11 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Wrong diagram, look at #14/15 here
https://www.discountinfinitiparts.co...iagram=3846050
I still don't see what's leaking in the OP's pic.
Old Jan 14, 2018 | 12:13 AM
Dillons VQ37
You won't see the leak in the pic. I can't get a pic. It's leaking from the bottom of the filler neck.
Old Jan 14, 2018 | 12:17 AM
JSolo's Avatar
JSolo
Just say no!!!!!
I suppose anything is possible, but I don't see how. The water outlet assembly is a cast piece. Developing pin hole leaks is not unheard of but is rare. More than likely the hose clamp has weakened and it's leaking where the hose attaches to the hose outlet. Fix is cheap, replace the clamp. Probably wouldn't be a bad idea to replace the hose too.
Old Jan 15, 2018 | 11:52 PM
Those oem clamps tend to take a set over time, the indents of the original clamp are visible on the hose showing that the clamp has been re-positioned. This can reduce the force on the hose, it also appears the hose is bulging a bit behind the clamp, this would indicate there may be some leaking there which tends to make the hose mushy in feel vs. a hose in good condition. Changing that hose and a new gear drive clamp would be a good plan. When removing that hose check for wear on the aluminum hose connection, pin holes & pitting can form there. If that's the case some jbweld should work. You would remove any oxidation w/ a dremel wheel then fully cure jbweld then sand smooth. hopefully just a new hose & clamp is all that's needed though. If like Jsolo mentioned, there is pin holes in that aluminum elbow below the hose, then that would have to be addressed.
G/L
Old Jan 17, 2018 | 08:40 PM
saywat?'s Avatar
saywat?
so no one sees the cap isnt on all the way?
Old Jan 17, 2018 | 09:52 PM
JSolo's Avatar
JSolo
Just say no!!!!!
I mentioned that in post #2.
No one reads previous posts?
Old Jan 18, 2018 | 09:13 AM
I did, I just figured that was corrected but
Sometimes it is the simplest things that get overlooked.
Do tell OP!
tite_tite
71
Mar 30, 2026 01:17 PM
tdoug
13
Jul 6, 2017 02:03 PM
jehu909
Jun 3, 2016 05:42 PM
tite_tite
Sep 25, 2015 10:21 PM
JSolo
General Tech Questions
Jul 9, 2015 01:57 PM
