Who has NOT had to replace their CSC on 6MT?
Old Sep 15, 2013 | 07:45 PM
toddmorr's Avatar
toddmorr
With all the stories about folks having their clutch pedal go to the floor and the resulting bad CSC diagnosis....I'm curious as to another view: How many of you have 6MT and have NOT had to replace their clutch slave cylinder? Please indicate your year and mileage.
I've got an '08 and about 31k miles and mine is going fine....am just curious as to the odds here...it would be reassuring if lots of you haven't actually had to replace it yet.
Old Sep 15, 2013 | 07:57 PM
bgoodman's Avatar
bgoodman
I have an 08 and I'm around 80K on the original CSC.
Old Sep 15, 2013 | 08:19 PM
Varjo's Avatar
Varjo
09 32k on the original CSC (though I do get a small rattling noise with the clutch depressed.... not sure what that's about).
Old Sep 15, 2013 | 09:03 PM
rgs3's Avatar
rgs3
08 Coupe 38k miles, I have no idea what an CSC is.
Old Sep 15, 2013 | 09:41 PM
Sco1oter's Avatar
Sco1oter
'08 G37S Coupe, second owner, 96K miles -- so far, so good.
Old Sep 15, 2013 | 11:16 PM
keraxis's Avatar
keraxis
Stock
2011 36k miles. CSC is fine.. syncros are not. I think you have to get a more agressive clutch to cause the failure. I know that it helps it along atleast.
Old Sep 16, 2013 | 12:17 AM
GW330's Avatar
GW330
08 G37s 17k still holding up, I did do a clutch fluid flush 100 miles ago and replaced with Motul RB660 because my pedal was acting up when cold. The difference in pedal feel was great! Air did come out while flushing plus the old fluid was NASTY!
BTW dont know about you guys but I find this car really hard to drive smoothly in terms of the clutch engagement pretty jerky. WHat about you guys?
Old Sep 16, 2013 | 01:31 AM
jjasonSU's Avatar
jjasonSU
Mine blew up last month at 38k miles
Womp womp
Old Sep 16, 2013 | 08:19 AM
DPE G's Avatar
DPE G
08 w/40k miles, mine was good but replaced it anyway when I did the TT kit & clutch. The OEM one is plastic is it's downfall, if you're ever in there for any reason, it's worth changing it out for peace of mind.
Old Sep 16, 2013 | 08:53 AM
pgviper's Avatar
pgviper
08 with 52k miles. Mine is fine.
However, I am planning on replacing the clutch all surrounding components in the spring.
Old Sep 16, 2013 | 09:10 AM
Can'tGme's Avatar
Can'tGme
08 with 42k, second owner. Going on fine *knocks on wood*
Old Sep 16, 2013 | 10:16 AM
CtCd7Accord's Avatar
CtCd7Accord
08 G37S with 62k. Second owner. Still on orginal CSC.
Old Sep 16, 2013 | 10:31 AM
cruzmisl's Avatar
cruzmisl
2008, 41k. I think if I make it to 50k without failing I will have it and the clutch replaced.
Old Sep 16, 2013 | 10:52 AM
JMS2000's Avatar
JMS2000
'13... around 20K miles, no issues.
Is that true that it results from aftermarket clutches? Or does the problem also occur with OEM clutches? Because I was thinking about going aftermarket when the time comes to replace mine...
Old Sep 16, 2013 | 12:36 PM
StoneColdG's Avatar
StoneColdG
I have a 08 w/ 116,000 and still going on original.
