09 G37 7AT Tranmission Question...
Hey guys I have a 2009 G37 7AT I bought 3 months ago. Recently when I come to a stop and try to accelerate, the transmission seems to hesitate rpm rises to about 2200, jerks then takes off. It almost seems like its slipping in the lower gears, but once it gets maybe about 3<SUP>rd</SUP> it seems fine. Is there anyway to check the transmission fluid to make sure its not low, also is there any way to check if the transmission reprogramming was done or to what version. Please advise I don’t want to take it to dealer unless for reprogram. If need reprogram does the dealer do it for free or charge?
Did you read this thread (towards the end)?
https://www.myg37.com/forums/g37-sed...reprogram.html
Short answer. Yes, you need the reprogram. It's free.
I got mine done and it fixed it for the most part. A month later and about 4,000 miles later its happening again. I have noticed the driving in sport mode basically takes care of the problem. I don't mind driving in sport until I take it in for my next oil change and have them take care of it then.
I'd have them check your cars' history and see if you've had the TSB applied, I doubt they had it done since you've had it about the time frame that the TSB was released for the 09s. It's a better overall drive after the TSB for sure.
Yea i think i will take it back to the dealer to see if the TSB has been updated. I think the leak happened with the oil cooler was being changed out, it was kinda of hard to add fluid had to get a long funnel...Thanks everyone
ScrewstonNismo
Feb 13, 2022 12:39 AM
Skyaddict
13
Nov 8, 2018 07:14 PM
