Idle problem
Old Mar 3, 2012 | 04:28 PM
G_man37's Avatar
G_man37
Idle problem
Here's is what I'm experiencing... While idling my car will shoot up Rpms on it's own. This happens when I'm in reverse gear or when the a/c is on or the heater is on.
It was suggested to me that I go to the dealer and get an idle relearn. I did that and my car was working perfectly. Then a couple hours later the same problem occurred. I was so mad that I wanted to drive my G straight into the lake.
I called the dealer today and they told to bring the car in for further diagnosing. I'm trying to avoid going back to the dealer as I am not made of money. Has anyone faced the same problem and had a solution. Any help would be appreciated.
Old Mar 3, 2012 | 05:29 PM
advan37's Avatar
advan37
Do not drive into the lake , i was planning to do it once but unfortunately we dont have lakes over here .
Old Mar 3, 2012 | 05:40 PM
SPN27RU's Avatar
SPN27RU
Try to Clean up throttles!
Old Mar 3, 2012 | 05:59 PM
G_man37's Avatar
G_man37
There is lake Ontario which i am seriously contemplating.
Old Mar 3, 2012 | 07:51 PM
NYG37S's Avatar
NYG37S
^ lols. kinda funny driving your car into a lake.
but check if there are any holes in you intake hoses, or resetting your ECU, clean TB as stated above.
Old Mar 4, 2012 | 02:29 AM
Steveo47's Avatar
Steveo47
check the throttle bodies for that black build up and clean it with throttle body cleaner if you have to. And make sure you dont hace a vaccum leak.
Old Mar 4, 2012 | 08:33 AM
Q8y_drifter's Avatar
Q8y_drifter
sounds like a vacuum leak. check all the hoses before taking it in to the dealer. I doubt it's carbon build up in the TB's.
vamarris
Dec 9, 2018 11:10 AM
butwhatuptho
Oct 4, 2015 07:51 PM
MrRiv
Sep 29, 2015 04:59 PM
k19g37x
Sep 29, 2015 02:46 PM
