Who has a Stillen G37 Supercharger? Numbers, pics, vids!
Old Feb 22, 2013 | 10:16 PM
  #136
dal1307's Avatar
dal1307
Originally Posted by jwfisher
Everybody here put an s/c on what was once their stock G.
Werd!!!!!
Old Feb 23, 2013 | 10:04 AM
  #137
bluedevils95's Avatar
bluedevils95
I was asking if you only have an exhaust and then the sc.
Old Feb 23, 2013 | 11:00 AM
  #138
dal1307's Avatar
dal1307
I believe that there are a few who either run a stock exhaust or started out with the stock exhaust but I can't remember who they were. Seems like one member made some pretty good power with the stock exhaust.
Old Feb 23, 2013 | 11:26 AM
  #139
jwfisher's Avatar
jwfisher
I have a picture in my garage of the stock y-pipe - it's tiny. Putting on a true dual exhaust system opened up a ton more power.
Old Feb 23, 2013 | 08:17 PM
  #140
bluedevils95
And they can see 400rwhp? What dyno was this
Old Feb 23, 2013 | 09:39 PM
  #141
jwfisher's Avatar
jwfisher
Yea, absolutely. But the exact HP doesn't particularly matter... this is not a car to run at the drag strip or take on Mustangs. What you have instead with this is what a very healthy V-8 G37S would have been like if the factory offered it. With a motor that breathes *very* well, across the wide spectrum. With low-end torque, a fast run up to the redline (which it'd like to go right past). Off boost the car is mild, almost normal, and on boost it's an animal. And the chassis (with the addition of swaybars and wider rubber), is entirely suited to this much power.
Old Feb 23, 2013 | 10:02 PM
  #142
Elperuano's Avatar
Elperuano
Lol Stillen...
Old Feb 25, 2013 | 02:50 PM
  #143
bluedevils95
Cool. Well i plan on this but want to get the headers and the drive shaft to add to the final number. How important is gages? I dont see them selling it w/ the kit
Old Feb 25, 2013 | 03:54 PM
  #144
jwfisher's Avatar
jwfisher
You don't need or want the headers for this project. Beefing up the driveline is ok but not really needed - at least at first (by the time they would be needed, you will alreadfy have blown the week pistons and rods).
Instead, you should consider starting small with the basic system (along with the largest oil cooler you can fit, such as Nismo's new racing kit, along with an oil thermostat - and same for an auto trans if that is what you are using), tune to that, and then take it up a notch at a time after that. Even the stock exhaust, restrictive as it is, would be a better starting point as far as tuning is concerned. Going past the manufacturer's kit recommendations is best done with iterative tuning and small careful steps. Remember, too, that the internals of this engine are very weak... you are not going to be able to go too far without breaking (or failing emissions).
Old Feb 25, 2013 | 04:14 PM
  #145
Elperuano's Avatar
Elperuano
Internals are not weak on this motor. Much improved over the DE motors.
I'm stage 2 TT at 540/500 at 12 lbs for 7k miles n this baby pulls with no problems.
Old Feb 25, 2013 | 04:47 PM
  #146
jwfisher's Avatar
jwfisher
Sure, but for how long? And for what use? Road racing? That won't last. Cruising around with the occasional pull? That will last for a while.
Now take it up to 15 pounds and 91 octane and see what happens.
Old Feb 25, 2013 | 06:15 PM
  #147
Elperuano's Avatar
Elperuano
Your statement that these motors are weak is completely false. I don't road race just on the street and where I live we have 93 octane.
Research and you'll find more g37s and 370s with similar power. Way more than any SC can produce and running fine. No need to give out false information.
Old Feb 26, 2013 | 01:34 PM
  #148
bluedevils95
Sooo... I am going to need those things and i should be fine. Oil and trans cooler?
Old Feb 26, 2013 | 02:33 PM
  #149
Elperuano's Avatar
Elperuano
Yes youll be fine.
Old Feb 27, 2013 | 12:23 PM
  #150
bluedevils95
I just want to know what to get since they don't come w/ it as i am looking at the parts.
Did you guys get them right away?
