G37 S Idle Issues
Old May 4, 2011 | 12:59 PM
mi135657's Avatar
mi135657
G37 S Idle Issues
What should the g37 S coupe typically idle at when its warmed up? My 08 sport idles between 850 and 1k after about 15 min of driving and it sometimes fluctates over 1k for a brief period of time. Is this normal and/or what would cause this? Thanks.
Mike
Old May 4, 2011 | 01:06 PM
huwee06's Avatar
huwee06
Dirty throttle bodies, should check them and cleaned every 15k interval or so with throttlebody cleaner. click on link for DIY
https://www.myg37.com/forums/d-i-y-i...le-bodies.html
Old May 4, 2011 | 01:12 PM
SRG's Avatar
SRG
take it to the dealership....i dont know if it's fully just the throttle bodies but get it checked out because thats not normal.
Old May 5, 2011 | 12:49 PM
surfjax87's Avatar
surfjax87
Correct idle is 600 +-50 rpm iirc. Check/clean those throttle bodies. I gotta get around to doing mine soon.
Old May 5, 2011 | 10:03 PM
akuma_83's Avatar
akuma_83
+1 Cleaning the TBs
Worked for me ! GL Bro !
Old May 5, 2011 | 10:26 PM
tomro99's Avatar
tomro99
i had this happen to me as well. went to the dealer and they updated my ecu. it was something computerized.
Old May 8, 2011 | 12:43 AM
mi135657's Avatar
mi135657
So the idle issue is basically an ECU update? I asked the dealership and they stated that its normal (which was a quick response), go figure. However, when it happens it seems as though power is lost by a much noticable amount in the lower rpms.
I cleaned my TB 2 weeks ago and it did not solve the issue. The TB was dirty though at 42k.
Old May 9, 2011 | 01:04 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
reset the ECU and see if that helps
Old May 9, 2011 | 07:07 PM
Staples's Avatar
Staples
Clean the MAF sensors and the dealership has to recalibrate the idle. It's a machine they hook into the OBDII sensor port.
the dreame
Apr 9, 2017 10:30 AM
Thedbarz
33
Feb 9, 2016 12:05 AM
Digilog
Aug 17, 2015 03:54 PM
SS2006
Aug 11, 2015 10:24 PM
bqbal
Intake and Exhaust
Aug 9, 2015 06:43 PM
