Injen Long tube CAI on 2011 G37 Sport
Old 03-26-2011, 07:14 AM
RadMav
RadMav's Avatar
Does anyone know if the Injen CAI will fit on the 2011 Sport with the fog lights?
Old 03-26-2011, 07:17 AM
wlmngtn
wlmngtn's Avatar
Very good questions, but I dont think so as I heard the washer fluid tank was a bit different due to the fog lights. Havent heard of any member here w/ injens on a '11 G.
Old 03-26-2011, 08:05 AM
eksigned
eksigned's Avatar
yes they will.
Old 03-28-2011, 04:24 AM
RadMav
RadMav's Avatar
Thanks for the feedback. I just rolled my '08 into a new 2011 lease. Pulled my Injen out of my '08 to put in the '11. Is there anything different I need to do on the install?
Old 03-28-2011, 08:08 AM
akochman
akochman's Avatar
You could either be your own guinea pig or contact Injen to see if anything has changed
To be safe, you should probably contact Injen unless you are feeling brave with the new G
Old 03-28-2011, 04:17 PM
eksigned
eksigned's Avatar
I don't believe so. I actually already have the Injen long tubes on my 2010 sedan. They fit right in. The initial issues I had with fitment were my fault; didn't take the time to remove EVERYTHING (duh). My long tubes came off a friend's '08 coupe. You'll be fine -- you won't have to modify anything to install. Enjoy!
Old 03-28-2011, 04:29 PM
Doggy
Doggy's Avatar
Did you have any issues with the injen, I'm might get the cai but unsure on the limp mode issue.
Old 01-28-2012, 10:41 PM
1SiCkG
1SiCkG's Avatar
they do NOT fit i tested and have them in now.. bottle wont clear fogs... injen sucks i called customer service they gave me a run around asked for pictures and never replied back
Old 01-28-2012, 10:53 PM
jamesshifflett
jamesshifflett's Avatar
Im running the Injen CAI on my 2011 sport n mine came with a new washer fluid take which allows the setup to work without issues
Old 01-28-2012, 11:33 PM
TVPostSound
TVPostSound's Avatar
James, you're a Sedan.
It wont work on Coupes, I have the 2011 fogs in my 2010.
Looking at another member's picture, I can tell the bottle is too fat at the bottom,
Old 01-29-2012, 12:31 AM
Rad_Slinger
Rad_Slinger's Avatar
Hit it with a heat gun and mold it to the shape you need it. It shouldn't damage the bottle at all. We're only talking a slight modification here, so it shouldn't be a big deal.
Just don't hold it too close to the bottle less u burn a hole in it.
Good luck.
Old 01-30-2012, 12:01 AM
RadMav
RadMav's Avatar
Good idea with the heat gun. I wanted the power more than windshield washer I just left mine off. 10 months with mine installed loving it dont miss the washer, but I'm going to try the great gun mod.
Old 05-18-2016, 04:12 PM
PNW_IPL
PNW_IPL's Avatar
Anyone know if this will work on an IPL?
Old 06-04-2016, 11:52 AM
TurkeyDirk
TurkeyDirk's Avatar
Any water issues?
Hi, I realize this is an old thread but I am considering putting the injen long tube cai (sp 1997) on my sedan, have you had any water issues with the filters being so close to the ground ( with or without hydraguard pre filters)?
Old 06-04-2016, 11:54 AM
TurkeyDirk
TurkeyDirk's Avatar
Any water issues?
Clutch34
06-24-2022 10:48 AM
Ricio1991
12
04-21-2022 01:39 PM
SpeedBallDEVIL
08-12-2015 04:30 PM
Ghost90
08-05-2015 11:19 AM
Quick Reply: Injen Long tube CAI on 2011 G37 Sport
