Supercharged VQ37 goes BOOM!
Old Mar 22, 2011 | 02:16 PM
  #46
Weiboy718's Avatar
Weiboy718
Originally Posted by irock
Still it just comes down to ability to tune it properly. GTM may be simpler to tune, I agree, but the kits themselves cannot blow the motor.
Plus here in AZ, it is always summer.
Are you running their kit by any chance?
  #47
Mike's Avatar
Mike
YES it does matters. The Stillen kit alters too much of the stock parts making it much much harder to tune. Just wait till summer time hit's. I can be sure some people is gonna have problems
Tuning is tuning. Changing parts doesn't make it "easier" or "harder" to tune. All you're doing is changing how much is flowing into and out of the engine. They're parameters, just like fuel and timing.
Now, if you were to cam the engine, or changing to higher compression, its a different story. At the end of the day, its just a VQ with more air going into it.
Old Mar 22, 2011 | 02:26 PM
  #48
Weiboy718's Avatar
Weiboy718
yeah you right. But still, this kit is much more difficult to tune right. Whoever say's they can tune this kit is full of ish lol even Stillen can't tune their own kit
Old Mar 22, 2011 | 02:40 PM
  #49
Mike's Avatar
Mike
How is it more difficult to tune?
All that's done is an alteration to the mass of air entering the engine, which is the same as the GTM kit.
Both of them use larger injectors.
Conceptually and mathematically, they are identical. Just the execution is different. In both cases, ALL aspects of the engine are identical mass the volume of air which is entering due to the nature of the respective blowers, and the injectors used.
Saying that the Stillen kit is harder to tune than the GTM kit, is like saying a setup with GT30s is harder to tune than a setup with GT28s.
The car doesn't care how the air is getting into the engine. Just how much is going in, what temperature it is, and how much fuel is available to combust with the air.
Old Mar 22, 2011 | 02:47 PM
  #50
Weiboy718's Avatar
Weiboy718
I understand what you're saying.
Have you noticed they relocated the dual Maf sensors.
Old Mar 22, 2011 | 02:49 PM
  #51
Mike's Avatar
Mike
But, they just measure the mass of air flowing into the engine right?
All they do is read a voltage, which is translated into a value. Location doesn't matter, as long as the reading is accurate.
Old Mar 22, 2011 | 02:56 PM
  #52
Weiboy718's Avatar
Weiboy718
Don't they read the air intake temp also and adjust air fuel accordingly. So what if the air is actually hotter than what the Maf's are reading
Old Mar 22, 2011 | 03:22 PM
  #53
irock's Avatar
irock
I am stock and have neither. My only mod is a radar detector.
I am just curious. I just fail to see how any one kit is more reliable than any other. The only way you can talk about reliablity of a kit is reliability of the actual parts themselves, not blowing a motor. The only possible way to blow the motor is a faulty tune, which someone could do with any kit.
If a part broke and fell in the motor I would agree. But you cant blame the inability of someone to properly tune a car reliabily on the kit. That is just like saying the kit is unreliable because it wasnt installed correctly.
Old Mar 22, 2011 | 03:50 PM
  #54
Weiboy718's Avatar
Weiboy718
In my eyes, no forced induction is reliable. A motor can blow with either kits. I personally had experience on both kits and I'm sure most of you probably know, so I'm really just speaking from experience. I considered myself being lucky to had not blown my motor running Stillen cann tunes. only me and GTM knows how bad my car was doing at that time. The parts Stillen uses is nice and well made not saying it's bad. Just the way how it's designed had major flaws imo. Even Stillen wasn't able to tune my car correctly. So if the manufacturer can't get it right who can or who else has the ability to do it
Old Mar 22, 2011 | 04:14 PM
  #55
irock's Avatar
irock
So you admit the kit is quality then. Your only issue is with the tune?
Old Mar 22, 2011 | 05:58 PM
  #56
theaudir8fan's Avatar
theaudir8fan
Ok seriously guys, why are you all bashing the points Weiboy is trying to make. I'm sure non of you have the experiences that he has had. In fact, I'm sure he is the only one who have had both kits on his car, and according to him, the GTM kit does the job much better. This is a source that i can rely on, user end feed back tell problems that just can't be explained on paper.
Altho, in my opinion, this might have been caused by the stillen kit itself, I don't think it's because of he added a header which caused the engine to blow up.
Old Mar 22, 2011 | 06:09 PM
  #57
Mike's Avatar
Mike
MAFs read air mass, so temperature is not a factor in the accuracy of the reading. Temperature doesn't affect the mass of air, but it does affect volume and/or density. (this is a really watered down explanation)
Old Mar 22, 2011 | 06:14 PM
  #58
Weiboy718's Avatar
Weiboy718
the kit does have some quality in it. Some parts are pretty well made but I would still won't recommend another member to buy it. I'll upload some pic's later on tonight and let you see.
Thanks, I think they're just trying to make a point saying it's all in the tunes. What I'm trying to say is how can you tune something that have flaws in it LOL
Copied this from another member and he's right on point:
Originally Posted by Staples
Stillen's kit uses an UpRev canned tune with their "turn-key" kit. UpRev uses the MAF sensors to actually tune the car, just like a factory tune. Think about it, we buy these cars worldwide; different elevation, different gas, different variances.
When you're tuning the vehicle, the MAF sensor is compensating the air, so if you say at full throttle I want to keep it around 11.5 - 11.6, then the MAF will compensate the air/fuel to see as close to those measurements as possible. Why do you think when you go with GTM's turbo turn-key kit, you don't need a custom tune sent to you if you decide to add test pipes, a 3" exhaust or anything else (thanks to the blow-through style MAF setup)? A lot of it has to do with Timing too. If you don't have an aggressive timing, you can get away with extra mods without needing a new tune.
What I think the issues is... the pull-through MAF system. You're not getting an accurate measurement of the air that's reaching the engine because it's being changed when it blows through the charger.
I've done a lot of research on this and there are a couple members I'd like to personally thank that have given me great insight on their review of this kit.
I could be wrong though :stirthepot:
Old Mar 22, 2011 | 06:35 PM
  #59
TheLocNar's Avatar
TheLocNar
So... after all of this... who installed the headers? Who was it that said no re-tune was necessary?
Old Mar 22, 2011 | 07:16 PM
  #60
Weiboy718's Avatar
Weiboy718
Probably the same person who told me DETONATION WAS NORMAL LOL
