G37 7speed transmission reprogram
Old May 23, 2012 | 12:23 AM
  #1096
Originally Posted by -Red-
Just to provide a quick update. During the commute back from work, I attempted to reproduce the lag that I have seen prior to the update, but interestingly enough, I wasn't able to do so. The car seemed considerably more responsive in the 20-30 mph range than what I'm used to.
I am still not quite ready to say this is solved until I get to do a bit more driving, but based on what I have seen so far I am cautiously optimistic. I'd like to see feedback from anyone else who's had their G updated.
Nice! Hopefully the good news will continue, keep us posted.
Old May 23, 2012 | 01:15 AM
  #1097
sniper27's Avatar
sniper27
waiting on more feedback before I get this second update. sounds good so far.
Old May 23, 2012 | 09:29 AM
  #1098
awais's Avatar
awais
Keep the good news coming! Hopefully us 09ers will get some love too.
Old May 23, 2012 | 09:51 AM
  #1099
blackhawksfan81's Avatar
blackhawksfan81
Originally Posted by mikeb2004
^^^ Yep. Scroll up the page for details....
ITB12-027 Released: 5/15/12
Do we have the text or a PDF of this yet? I want to see if my VIN is included.
Old May 23, 2012 | 10:34 AM
  #1100
mikeb2004's Avatar
mikeb2004
I will try to get the VIN range from my dealer today when I drop the car off for the update. I should get the car back this afternoon.
Old May 23, 2012 | 11:07 AM
  #1101
nishalp's Avatar
nishalp
No VIN's. Based on ECM and TCM Part Numbers... Hope this helps out.
2010 - 2011 G37; SHIFT RESPONSIVENESS ISSUES
APPLIED VEHICLES: 2010-2011 G37 (V36/CV36)
APPLIED ENGINE: VQ37VHR
APPLIED TRANSMISSION: 7 speed
IF YOU CONFIRM
One or more of these conditions:
<DIR><DIR>• Harsher than expected down shifts when coasting to a stop.
• Hesitation/lag when accelerating after coasting.
• Hesitation/lag or harsher than expected down shifts when coming to a stop and accelerating again (rolling stop).
• Engine rev matching during moderate to heavy braking.
NOTE:
This is normal ASC (Adaptive Shift Control) operation that can be removed from normal drive mode, but will remain in sport mode.
</DIR></DIR>
ACTION
  1. Refer to step 6 in the SERVICE PROCEDURE to confirm this bulletin applies to the vehicle you are working on.
  2. If this bulletin applies, reprogram the
    ECM and TCM.
SERVICE PROCEDURE
This procedure will require reprogramming of the ECM and TCM; which means most steps in this procedure will need to be done twice.
  • Most instructions for reprogramming with CONSULT-III plus (C-III plus) are displayed on the CONSULT PC screen.
  • If you are not familiar with the reprogramming procedure, click here. This will link you to the "CONSULT- III plus (C-III plus) Reprogramming" general procedure.
Preparation for Reprogramming
NOTE:
  • After ECM reprogramming is complete, you will be required to perform Throttle Valve Closed Position, Idle Air Volume Learn (IAVL), and Accelerator Closed Position.
  • The above conditions are required for the IAVL to complete.
  • Take the vehicle for a 10 minute drive in order to meet the following Idle Air Volume Learn (IAVL) conditions:
    • Engine coolant temperature: 70 -100°C (158 - 212°F)
    • Battery voltage: More than 12.9V (At idle)
    • Transmission: Warmed up
<DIR></DIR>CAUTION:
  • Connect a battery charger to the vehicle battery. The vehicle battery voltage must stay between 12.0V and 15.5V during reprogramming, or the ECM/TCM may be damaged.
  • Be sure to turn OFF all vehicle electrical loads. If a vehicle electrical load remains ON, the ECM/TCM may be damaged.
  • Be sure to connect the AC Adapter. If the CONSULT PC battery voltage drops during reprogramming, the process will be interrupted and the ECM/TCM may be damaged.
  • Turn off all external Bluetooth® devices (e.g., cell phones, printers, etc.) within range of the CONSULT PC and the VI. If Bluetooth® signal waves are within range of the CONSULT PC during reprogramming, reprogramming may be interrupted and the ECM/TCM may be damaged.
Current ECM or TCM Part Number column in Table A on next page.
  • If there is a match, this bulletin applies. Continue with the reprogramming procedure.
  • If there is not a match, reprogramming does not apply. Make sure to check both ECM and TCM for a match.
<TABLE dir=ltr border=1 cellSpacing=0 cellPadding=7 width=589><TBODY><TR><TD bgColor=#ffffff height=11 vAlign=middle width="55%">Table A - ECM Model
</TD><TD bgColor=#ffffff height=11 vAlign=middle width="45%">Current ECM Part Number: 23710 -
</TD></TR><TR><TD bgColor=#ffffff height=85 vAlign=middle width="55%">2010 G37
(V36/CV36)
</TD><TD bgColor=#ffffff height=85 vAlign=middle width="45%">1MW0A, 1NS0E, 1NS0B, 1NS0A, 1MW0B, 1NS0D, 1NS0C, 1MW2A, 1NS2E, 1NS2B, 1NS2A, 1MW2B, 1NS2D, 1NS2C, 1MW1A, 1NS1E, 1NS1B, 1NS1A, 1MW1B, 1NS1D, 1NS1C, 1MW3A, 1NS3E, 1NS3B, 1NS3A, 1MW3B, 1NS3D, 1NS3C, 1MW6A, 1NS6E, 1NS6B, 1NS6A, 1MW6B, 1NS6D, 1NS6C, 1MW7A, 1NS7E, 1NS7B, 1NS7A, 1MW7B, 1NS7D, 1NS7C, 1PX0A, 1NG0E, 1NG0B, 1NG0A, 1PX0B, 1NG0D, 1NG0C, 1PX2A, 1NG2E, 1NG2B, 1NG2A, 1PX2B, 1NG2D, 1NG2C, 1PX1A, 1NG1E, 1NG1B, 1NG1A, 1PX1B, 1NG1D, 1NG1C, 1PX3A, 1NG3E, 1NG3B, 1NG3A, 1PX3B, 1NG3D, 1NG3C, 1PX7A, 1NG7E, 1NG7B, 1NG7A, 1PX7B, 1NG7D, 1NG7C, 1PX8A, 1NG8E, 1NG8B, 1NG8A, 1PX8B, 1NG8D, 1NG8C,
</TD></TR><TR><TD bgColor=#ffffff height=39 vAlign=middle width="55%">2011 G37
(V36/CV36)
</TD><TD bgColor=#ffffff height=39 vAlign=middle width="45%">
1NX0B, 1NX0A, 1NX0D, 1NX1B, 1NX1A, 1NX1C, 1NX2B, 1NX2A, 1NX2C, 1NX3B, 1NX3A, 1NX3C, 1NX6B, 1NX6A, 1NX6C, 1NX7B, 1NX7A, 1NX7C, 1VU0B, 1VU0A, 1VU0D, 1VU1B, 1VU1A, 1VU1C, 1VU2B, 1VU2A, 1VU2D, 1VU3B, 1VU3A, 1VU3C, 1VU6B, 1VU6A, 1VU6C, 1VU7B, 1VU7A, 1VU7C,
</TD></TR></TBODY></TABLE>
<TABLE dir=ltr border=1 cellSpacing=0 cellPadding=7 width=575><TBODY><TR><TD height=11 vAlign=middle width="54%">TCM Model
</TD><TD height=11 vAlign=middle width="46%">Current TCM Part Number: 31705 -
</TD></TR><TR><TD height=39 vAlign=middle width="54%">2010 - 2011 G37
(V36/CV36)
</TD><TD height=39 vAlign=middle width="46%">X439C, X380B, X211E, X184D, 3RX3D, 3RX0C, 1XJ4A, X439D, X380C, X211B, X184E, 3RX4A, 3RX0D, 1XJ4B, X439E, X382C, X211C, X183B, 3RX6D, 3RX1A, 1XJ4E, X450A, X382D, X211D, X183C, 3RX6E, 3RX1B, 1XJ5A, X438C, X350E, X438D, X351A, X438E, X359C, X351B, X439A, X359D, X458D,
Old May 23, 2012 | 11:08 AM
  #1102
nishalp's Avatar
nishalp
Deleted - Double Post
Old May 23, 2012 | 11:17 AM
  #1103
benvwin's Avatar
benvwin
Has anyone successfully convinced the dealership about the 2009s? Mine is still not as smooth as the newer ones that I've driven before.
Old May 23, 2012 | 11:30 AM
  #1104
sniper27's Avatar
sniper27
how do we check our ECM/TCM #?
Old May 23, 2012 | 01:12 PM
  #1105
nishalp's Avatar
nishalp
Was wondering same thing. Seems like per the note, Consult III to get it at the dealer...
Old May 23, 2012 | 02:36 PM
  #1106
njnewsman's Avatar
njnewsman
Originally Posted by Almatti
JackM, re-progammed or not, the 7AT is problematic.....check the member post that provided the link to the article a page or two back. The article specifically cites the numerous complaints about Nissan's 7AT (yes, it is a Nissan tranny). Yesterday, while driving on a local suburban road at 35-40 mph, not fully warmed [but doesn't seem to matter anyway], stepped on the brakes to allow a car in front to make a turn, then stepped on the gas and what hesitation: count 1....2..... felt like the car stalled, then vrooom, it takes hold and takes off. I can't stand it.
I know this is a bit dated, but this is exactly how I feel about my 2011 G37. I truly cannot stand it! Every time you brake and then accelerate you get that gosh awful 1-2 second hesitation. The absolute worst driving experience ever. Sad, because the car is overall a good car.
Old May 23, 2012 | 04:31 PM
  #1107
njnewsman's Avatar
njnewsman
Getting the new 027 Flash tomorrow!
Originally Posted by MaluG37
Duane Salerno Infiniti
I am having Duane Salerno Infiniti in Denville apply the new ECM flash tomorrow. Can't wait. Hope it finally addresses the issues.
Will let you all know. Thanks for posting the new tech bulletin.
DOMO
Old May 23, 2012 | 06:12 PM
  #1108
firstinfiniti's Avatar
firstinfiniti
I have the car in the shop, getting the update. The SA said that they are fully aware of the issue and have had a bunch of customer complaints about the transmission already. He also mentioned a Stillen grounding kit that helps the hesitation; doesnt fix it. He said that there is a lag in communication between the computer and trans/throttle position/revs/torque converter. There is nothing that they, the dealership, can do other than to wait on Infiniti to come out with a fix. According to Infiniti, its operating the way it is designed. At least he didnt feed me BS and was honest about it. Anyone try the Stillen grounding kit and notice a difference?
Old May 23, 2012 | 08:25 PM
  #1109
mikeb2004's Avatar
mikeb2004
Back from dealer. Got the reprogram done on my 2011
First impressions:
_____LAG_____IS______GONE______
DOMO (yes 8 of them)
Yep, got my update today. No more delay/lag. Didn't get to put a lot of miles on it yet, but it also seems to respond more quickly to your right foot (downshift), and pulling away from a stop seems a bit easier to modulate. Before, it was hard to pick anything between "slow" and "rocket launch" mode.
Almatti, are you here? RUN to your Infiniti dealer!!
Old May 23, 2012 | 08:44 PM
  #1110
hobbs's Avatar
hobbs
"He also mentioned a Stillen grounding kit that helps the hesitation"
Typical service adviser, absolutely no clue what he is talking about.
Unless wires are loose and/or corroded, a grounding kit will do nothing except separate you from your money.
