G37 7speed transmission reprogram
Old Mar 16, 2014 | 08:42 PM
  #2281
scottp2765's Avatar
scottp2765
Originally Posted by Chris11LE
How many miles were on your car that you changed the xfer case oil?
Only 25k miles.
Old Mar 23, 2014 | 12:12 PM
  #2282
rare37s's Avatar
rare37s
Just had my 2010 S Sedan updated yesterday. No more lag or downshift jerks at all, throttle is noticeably more responsive and gear shifts both up and down are alot smoother. I was in debate about having it done but just bit the bullet because it was under factory warranty. My service advisor looked up the update by my vin. The car now feels like it has some real horsepower and i would highly recommend to have it done.
Old Mar 27, 2014 | 12:43 AM
  #2283
Muujig612's Avatar
Muujig612
I've seen a guide on how to update the tranny, but I can't find it, if anyone know where it is please help me. I'm from Mongolia and the Nissan dealer technician has no idea what I'm talking about when I mentioned the update to him and he said if I can find out how to do it he will update my car tranny.
Please HELP!
Old Mar 27, 2014 | 11:22 PM
  #2284
jazzmang's Avatar
jazzmang
They hook it up to their CONSULT 3 unit and they can search for any applicable updates.
Old Apr 2, 2014 | 07:06 PM
  #2285
rm2342's Avatar
rm2342
^ Well, went to the dealer today for a headlight that was out and complained while I was there about the transmission. They gave me the 027 Update.
I will have to report back on how it works out under normal driving. They said to try it out and see how the update works out for me and if I wasn't happy bring it back in??
I have a 2011, wonder what they would do if I was unhappy with the 027 update???? Anyone?
Old Apr 2, 2014 | 07:11 PM
  #2286
scottp2765's Avatar
scottp2765
Voodoo Dance...
Old Apr 2, 2014 | 07:16 PM
  #2287
rm2342's Avatar
rm2342
I don't know if that was the answer I was looking for
Old Apr 2, 2014 | 07:49 PM
  #2288
hobbs's Avatar
hobbs
Originally Posted by scottp2765
Voodoo Dance...
Works for resetting the ECU and grounding wires too!
Old Apr 3, 2014 | 07:01 PM
  #2289
rm2342's Avatar
rm2342
^ None of that SH%#, but so far I am liking the reflash. It accelerates much smoother and more seamlessly. When using manual mode the shifts are a bit quicker and again smoother. So far very happy.
Hopefully re-learn will not default to prior behavior.
Old Apr 4, 2014 | 03:26 PM
  #2290
G37XSER's Avatar
G37XSER
Well, I'm going to take the plunge and get my TCU updated. I never really had much of a problem with it until recently, the dang thing started doing everything that people on this forum have been complaining about. Here I thought I was out of the woods since it has 64K on it and it wasn't bad yet. It scared the he** out of me yesterday coming to work, when I had to get out of the way of a car coming at me from the left and, until I put the pedal THROUGH the floor, it just sat there for almost 3 seconds. I immediately called Lupient Infinity locally here and made an appointment. The Advisor (??!!) knew right away that it needed the TCU updated and said they would have me in and out in about 20 min. Next Wednesday is my appt and it can't come soon enough. I'm SO glad they didn't give me the run around on this. Now I'm just hoping they don't try and charge me for this...especially since I was a sucker and got the Premium 7/100,000 warranty.
Old Apr 25, 2014 | 07:28 PM
  #2291
NSH PREDS's Avatar
NSH PREDS
I recently purchased a 2011 G37x (30k) and didn't notice anything wrong while on the test drives. However once I had the car for a few days I noticed something strange. I was cruising to a red light and the car starts aggressively down shifting and for a second I thought my brakes were applying. This continues to happen after weeks of ownership, as well as some lag or hesitation on different occasions. The car is still under warranty so I took it to the local dealership, for a different very minor issue, and mentioned the transmission quirks while I was there. They said no problem and that they would check it out. Got a call back later saying that they were going to perform an ECM reprogram which falls under the warranty. I don't have the car back yet, but once I do I will be sure to report back with an update.
Aside from that issue I have enjoyed the car and miss it already.
Old Apr 26, 2014 | 12:11 PM
  #2292
TinsleyC's Avatar
TinsleyC
NSH, I'm sure you will like the way it drives when you get it back. The flash is a LOT smoother, and seems to hold the gears a little longer when in the higher RPM's. It just seems to be in the right gear all the time which was not the case before.
Old Apr 26, 2014 | 01:14 PM
  #2293
mugwah's Avatar
mugwah
Angry g37x2012 transmission lagging gear searching etc.,
I will be in lemon law arbitration 175 Fulton ave Hempstead ny may 8 1:00 pm suit 400 any of you want to voice your concerns about the 7 sp. a/t problems to the robots of infiniti north America reps.[ car operating as design]! my email ispro@optonline.net, mugwah
Old Apr 27, 2014 | 09:24 AM
  #2294
KCMO's Avatar
KCMO
Just got the TSB reflash and it was a night and day difference on my '10 g37xs sedan. The car is actually driveable without cursing and cringing while it tries to figure out how proper gear changes should happen.
Old Apr 28, 2014 | 08:59 AM
  #2295
G37XSER's Avatar
G37XSER
I finally got the update done, and I must say, it is WAY better at shifting than it was before. I am REAL happy with it now, not just happy. I haven't run it through every variable yet, but after about 700 miles, it is a real joy. Hopefully it doesn't revert back to its bad habits. Good luck.
David
