G37 7speed transmission reprogram
Old Aug 20, 2013 | 09:12 PM
  #2176
LilRocket's Avatar
LilRocket
I'm going to get this done on my 09 xS. I've noticed the shift lag when accelerating after coasting but now it also started to harshly down shift when coasting to a stop. I think it has come to my attention more now with the new exhaust how it up-revs (500-700rpm approximately) when down shifting from 2nd to 1st gear. Hopefully this ECM/TCM reprogram fixes or at least reduces the issue
Old Aug 21, 2013 | 02:26 PM
  #2177
RSVracer's Avatar
RSVracer
let us know how it goes
Old Aug 21, 2013 | 07:48 PM
  #2178
WannabeSport's Avatar
WannabeSport
My 2013 shifts like **** too. Apparently I am already the most updated I can get.. :/
Old Aug 21, 2013 | 10:51 PM
  #2179
Almatti's Avatar
Almatti
Don't forget the original advise I received when I was a regular participant with frequent posts about the 7AT.....Drive your car in DS mode for a week or more. Drive it hard and aggressive. Then see if she reacts a little differently. It seem to work to some extent. I'm in a 2013 M37X now, at times it exhibits similar behavior - not as bad - but it rears it's ugly head now and then. I drive my M in Sport mode (it's a little different than the G DS mode), and she begins to drive and respond better.
Old Aug 24, 2013 | 09:34 PM
  #2180
Imua1's Avatar
Imua1
Sounds as though you have gotten used to and accepted the quirky traits of the 7AT. First in a G and now in an M. How much nicer would it be to just keep it in Drive and have it be acceptably responsive, like most all other sport sedans?
Old Aug 25, 2013 | 07:27 AM
  #2181
Almatti's Avatar
Almatti
Imau1: I have driven other recent vintage cars available at my place of employment (2012 Ford Taurus, 2011 Lincoln MKS,etc...) which have 6 ATs. They exhibit those hickups too, not quite as bad, but thye have 1 less gear. An associate of mine who regularly drives a Lincoln MKS says that the dealer resets the ECU and within a week or so, it starts with some hesitation and quirkiness. It seems this is the wave of the Future with automatic Trannys.
It's the principal way to achieve better MPGs. For example, on my new M37X, which I do really enjoy overall, I'm achieving 23-24.5 MPGs with suburban City and Highway driving including NY area traffic. I think for this heavy and powerful car: That's pretty good. I use only Premium gas despite what others say that you can use Mid grade or even 87 Octane gas. The Variable Valve engines with electronically controlled timing can adjust to the lower octanes without pinging, but the mileage and POWER sacrifices that I won't make. I only have about 2200 miles on my M to dtae, so it's far from fully broken in...
I've also driven a 2013 Ford Escape with Eco-Boost engine (I think it was a 2.0, but there were no markings on the engine compartment or anywhere else to indicate if it was the 1.6 or 2.0 -Enterprise rental car). It had a 6AT (I think) and she was very responsive with little hesitation. It was NOT a CVT for sure (we have one in our 2010 Subaru Legacy [it too is pretty responsive but does take getting used to]. The Eco_Boost engines are turbo charged with direct fuel injected engines which did NOT shoe that typical Turbo Lag at all. During my test drives for considered replacement cars for my expiring 2010 G37X, overall the winner without a doubt was..... a 2013 Audi A-6 3.0 Quattro - fast, responsive, fantastic handling, very little lag in all driving modes, comfortable BUT expensive. I think as a runner up, for the $$$$$$ value, the M hit the mark. Better than the MB E350 (2013) too IMO.
Old Aug 25, 2013 | 08:46 AM
  #2182
rm2342's Avatar
rm2342
Did you get this done? Curious if successful where you went in Ma.
Old Aug 28, 2013 | 10:59 AM
  #2183
unknown2k1's Avatar
unknown2k1
I gave up on this battle. Took to two different dealership, including the one I bought from - have all told me that my ITB10-075 is the newest/latest one for me even though Service Bulletin points back to 2010 instead of the new ITB12-027. I'm sure there are people like me but at this point, I've given up!
Old Aug 28, 2013 | 01:12 PM
  #2184
RSVracer's Avatar
RSVracer
unknown,
sorry to hear that. I'm in the same boat, my friend.
Old Aug 28, 2013 | 02:14 PM
  #2185
Silvermink's Avatar
Silvermink
Hmm, I guess that's what was wrong with the '09 I test-drove before getting my car; it felt like it was engine braking really hard when I let off the gas when coming to a stop. I assume it's already been done on my '10 since the shifting doesn't feel funky.
Old Aug 28, 2013 | 02:18 PM
  #2186
RSVracer's Avatar
RSVracer
could be. Only way to tell would be to bring both to the dealer and have them check the current software/firmware revision.
Old Aug 29, 2013 | 03:04 PM
  #2187
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
ok so question for all who have had the firmware update...took my 10" 37s sedan to my local dealer this past sat and told them about the harsh transmission/lag and wanted the update performed. So of course they make a technician ride in my car first. Guy tells me that the update can be performed but I will lose responsiveness and car will be even more sluggish when wanting to speed up quickly. And told me performance will not be the same? I havent read that anywhere but wanted to know your feelings on this....is your car less responsive and performance feel like it decreased?
Tech even said that he performed the upgrade for a friend who was so upset at the way the car perfomred afterwards that the guy went and bought a ECU from a junk yard to put it back to the old oem ecu settings
Old Sep 5, 2013 | 03:35 PM
  #2188
Daddy Fat Sacs
ok anyone????????????????????????
Old Sep 5, 2013 | 05:41 PM
  #2189
CRiME's Avatar
CRiME
I experienced no side effects after the update. All of the shifting bugs were hammered out and the transmission was noticeably more responsive. If you can, try a different dealership and see what they have to say.
Old Sep 5, 2013 | 06:42 PM
  #2190
LilRocket's Avatar
LilRocket
I was on vacation and called in yesterday to my dealer Prime infiniti to scheduled my service but I cannot go in until Friday the 13th lol so I'll let you know my results after that
