Due for an oil change/need advice
Old Oct 29, 2010 | 12:19 AM
TinsleyC's Avatar
TinsleyC
Originally Posted by brownsoldier
Man this is too confusing... So what Ester based oil can I use that way I can go to like a Midas or Sears and get it done there???
As others here have said, if you change it often it really doesn't matter if you choose a decent oil. If you want the best oil recommended by Infiniti, use their Ester oil, but it's expensive. If you want a readily available good oil, use a top shelf synthetic. At Midas or Sears they will likely have Mobil 1 or Pennzoil Platinum, maybe a Castrol synthetic but prob won't have Pennzoil Ultra as it's still new.
I bought some PU and my Purolator PL14612 filter and took it to Sewell Infiniti of Dallas and they changed it for about $30-something.
Old Oct 29, 2010 | 01:08 AM
4drScreamer's Avatar
4drScreamer
I bought some PU and my Purolator PL14612 filter and took it to Sewell Infiniti of Dallas and they changed it for about $30-something.[/QUOTE]
Going to pick up some Pennzoil Ultra and a Purolator this weekend. Thanks for the recommendation!
Old Oct 29, 2010 | 11:10 AM
LightsOut's Avatar
LightsOut
Originally Posted by TinsleyC
Interesting... anyone know what class Pennzoil Ultra is in?
thats the same class as mobil1, castrol and all other shelf oil.
Old Oct 29, 2010 | 11:12 AM
LightsOut's Avatar
LightsOut
Originally Posted by KLB
It actually says to use "Nissan Ester Oil",not just ester based oil. And it appears that their oil is not ester based.
I believe nissan oil is dino oil with ester in it. but they market it as ester oil.
Any higher end oil will have ester in it.
Guys do some searching on class of oils. You'll begin to figure out that Mobil1 sux for our cars.
and this Ester oil stuff is an option for guys....
Back in the days Mobil1 was a full synthetic oil, but then they went cheap and marketed their oil as full syn. but they had changed their oil to a lower class. Which got them a sued by Castrol for false advertisement.. more to the story but that's just a break down.
Old Oct 29, 2010 | 11:37 PM
robxc80's Avatar
robxc80
where can you find penzoil ultra? pep boys, o'reilly, autozone, and walmart only have up to penzoil platinum.
i want to use the ultra since i read so many good things about it but i can't seem to find it anywhere. Since i can't find it, i buy Mobil 1 5w30 since its $25 for a 5qt jug...that and a K&N filter and i pay 15 bucks to get it changed at a local mechanic.
Please chime in if you know where i can find penzoil ultra.
Old Oct 30, 2010 | 12:46 AM
ozzypriest's Avatar
ozzypriest
Penzoil Ultra has no ester compunds in the formulation. However, Penzoil Plat and Ultra both show good Blackstone results, much better than Mobil 1. I would just use Penzoil Platinum, change it every 5k or so and I would imagine your engine will be fine. Good high grade detergent gas helps a lot too.I like Shell for no particular reason other than people I know in the industry say its got great cleaning additives. For that matter, so does PP or PU.
You can either perseverate like an pathological OCD nutcase over which oil to use, which a looooot of enthusiasts do to no good end, or you can go by oil analysis from Blackstone labs, which is probably the most logical and 'scientific' method to determine what oil direction you should go in, or you you can just go buy oil based on advertising malarky from the high-end producers like Motul or Royal Purple or Amsoil, etc, or by what some dude you don't know from adam suggested on a forum.
People worry way too much about oil.
Old Oct 30, 2010 | 01:14 AM
TinsleyC's Avatar
TinsleyC
If you're searching by name, use another "n" - Pennzoil.
Go to the www.pennzoil.com website, click on Find Pennzoil Products and that may help. I get it at WalMart in Dallas TX.
Old Oct 30, 2010 | 09:24 AM
KLB's Avatar
KLB
I get mine at Walmart.
Old Oct 31, 2010 | 12:25 AM
ozzypriest's Avatar
ozzypriest
me too - mea culpa for the misspel. pe(nn)zoil! PP for like 23 buxks for 5 liters at walmart. Ultra for around 27? 29? for 5 liters, something like that.....
Old Oct 31, 2010 | 09:50 AM
KLB's Avatar
KLB
It was down to $25 last week when I bought my latest jug. 50 cents more than Mobil1, and I think only like $2 more than Platinum.
Old Nov 20, 2010 | 05:44 PM
Panamajon's Avatar
Panamajon
When you buy the oil yourself and bring it to a Nissan dealership, what are you charged?
Same question for taking it to Sears.
I just hit 3700 miles on my 2010 G37 convertible and need to get 'er done.
Old Nov 20, 2010 | 10:13 PM
TinsleyC's Avatar
TinsleyC
I took some Penz Ultra and a Purolator PL14612 to Sewell Infiniti of Dallas and they charge me $32 plus tax to change it. They also filled my BlackStone Labs bottle for me (for analysis) and did it well (no spills, bottle was full, was caught mid-stream, so they said).
Wal-Mart sells the oil too but I'm not sure I trust them so well...
rk325
Oct 13, 2015 01:51 PM
delfinparis
Oct 8, 2015 06:06 PM
Junchao Sun
25
Oct 1, 2015 12:41 PM
BurtoN86
Sep 30, 2015 03:32 AM
Slapshot1
Sep 27, 2015 08:40 AM
