Review Used Oil Anlysis on ENEOS (5300mi)
Old Jul 20, 2010 | 09:10 PM
ucla bruin's Avatar
ucla bruin
Virgin ENEOS sample
UOA
Combined.
Looks good to me but I'm no expert. What do you guys think?
__________________
Old Jul 20, 2010 | 09:33 PM
philter25's Avatar
philter25
Im no expert either, but the good news is it didnt shear at all and your wear metals are all low.
Im kinda shocked at the additive package, its pretty simple and pretty basic. If you check out the other VOA's of other common oils, you will see that its probably the simplest of them all. Compare it to the recommended Nissan Ester oil. Its got more ppm of everything the Eneos has and a ton of Moly.
https://www.myg37.com/forums/engine-...-analyses.html
Calcium and Magnesium are detergents, and phosphorous and zinc are anti-wear additives. Thats it. Simple.
And this is also a semi-synthetic oil, correct?
If you told me that you had a semi-synthetic oil with this basic additive package that didnt shear and easily held up and looked good in our cars for 7500 miles, I would have called you and BB a liar.
Old Jul 20, 2010 | 10:42 PM
SM_Shadowman's Avatar
SM_Shadowman
As another pure amateur who for some reason has read a thousand of those UOAs in the past year, I like it . Looks like it maintained viscosity for 5000+ miles.
The website stats Mike posted in the other thread claimed an initial TBN of 6.4. So that's looking good too, like they said.
Glad I just put the stuff in my car a few weeks ago. I'll get a UOA done when I change it -- I'll be running 5K also.
Old Jul 20, 2010 | 11:33 PM
GeeeeOhhhh's Avatar
GeeeeOhhhh
Just put in some ENEOS 5W30 in the G today thanks Danny for giving me the confidence in switching from castrol edge to ENEOS
Old Jul 21, 2010 | 01:29 AM
Originally Posted by philter25
...And this is also a semi-synthetic oil, correct?
So often we tend to make things harder than they have to be. So many people in the automotive community will tell you what won't or can't work based on absolutely nothing at all. It's not fully synthetic. It's not ester based. It's not the most expensive or latest. But it just works well. Don't ask me to explain how or why, it just does. And that's good enough for me.
I'm sure some will have their reasons that they'll hold on to as to why XYZ is allegedly so much better. I'll stick to what I know.
Old Jul 21, 2010 | 03:58 AM
STOOF's Avatar
STOOF
I just got an oil change last week. Ran Eneos 0w50 for 9600 miles lol 13k-22.6k. The oil looked fine, didnt see any metal flakes or anything.
I put 5w30 this time though since i run it so long.
Old Jul 21, 2010 | 08:22 AM
philter25's Avatar
philter25
I hope you and BB dont mind, but I posted your UOA's on BITOG to see if anyone there can shed any additional information.
Old Jul 21, 2010 | 08:58 AM
CougarRed's Avatar
CougarRed
So here's a recent 5000 mile UOA on PP on a mature G37 engine:
Wear metals even better than ucla bruin's latest report. But ending viscosity thinner. TBN about the same.
PP at Walmart costs a lot less than Eneos at Amazon. Is Eneos worth the extra money?
Old Jul 21, 2010 | 09:47 AM
philter25's Avatar
philter25
Are there any other PP UOA's around or is there just only 1 to go by?
BB showed the Eneos can go almost 10k miles without shearing, has anyone driven the full 7500 on Platinum with a UOA?
I never trust just one single piece of data in a data set because as we have seen with many other oils, UOA's can vary dramatically from driver to driver depending on how the car is driven...... although I feel like a broken record and have said this in other threads before.
And when you say "even better", we are talking about a few PPM here. Depending on WHERE and WHEN you get your oil from to send it for a UOA, it will vary a few PPM.
When you are draining your oil, if you take the oil out immediately and compare it to the oil which you take out at the end, you are going to see a difference in PPM across the board.
Old Jul 21, 2010 | 01:15 PM
ucla bruin's Avatar
ucla bruin
Don't mind at all. Thanks for posting!
Sample was taken in the middle of the drain. Not beginning or end.
I'll try to go 7500mi next, closer to what BB has done on his UOA, hopefully we'll have consistent results on ENEOS.
__________________
Old Jul 24, 2010 | 05:01 PM
CougarRed's Avatar
CougarRed
Originally Posted by ucla bruin
Sure looks like your VOA lab report is way off. Boron, Calcium, Zinc, Phosphorus and Magnesium are all significantly higher on both your UOAs (and both Black Betty's UOAs) compared to this VOA.
Old Aug 3, 2010 | 08:42 AM
philter25's Avatar
philter25
Danny,
Send an email to Blackstone and have them re-run your VOA sample. Re-send them your VOA and UOA and point out the calcium, phos, and zinc. They will re-run it for free because its not right.
Old Aug 3, 2010 | 01:29 PM
ucla bruin's Avatar
ucla bruin
I'll look into it. Thanks.
__________________
fuzzed
Aug 21, 2020 09:35 AM
Stevolkz33
May 28, 2016 02:36 AM
Junchao Sun
25
Oct 1, 2015 12:41 PM
Chappedj
Sep 28, 2015 03:20 PM
Ricio1991
Sep 8, 2015 09:43 AM
