Stillen/GTM Supercharger Pros, Cons, and Questions
Old Mar 25, 2013 | 11:42 PM
  #181
Elperuano's Avatar
Elperuano
You're running a meth set-up for a SC??? A Stillen SC??? Lols.
Way overkill and in the short and long run costing u a lot of money.
Curious, how much did ur meth set-up cost?
Old Jul 24, 2013 | 03:23 PM
  #182
Muujig612's Avatar
Muujig612
Hi guys,
I have a 2011 G37x that comes with AWD and a 7 speed auto transmission, as all of you know, the Infiniti 7 speed auto transmission isn't the fastest of them. So, I was wondering, for my case, is it better to have a twin-turbo or supercharger? What advantages twin-turbo has over superchargers?
Thanks
Old Jul 25, 2013 | 04:05 PM
  #183
SPDCRZ's Avatar
SPDCRZ
A Meth setup is not that expensive if you do it right. And I am not sure how you think its overkill. In fact I noticed quite a bit of difference after install.
I still don't get why people don't like the Stillen SC. If installed correctly it runs AMAZING! The only issue is that many of the people quoting they have done it and its not worked well have not done correct installs. You can not use the wiring supplied and you have to make sure you do everything right "to a T". If its done professionally and correct, you will have amazing results!
As I heard it mentioned in another thread. "We here about all the bad installs for the Stillen SC but never here about the ones that are installed correctly and run great"... ie. me! I love my Stillen SC and wouldn't trade it for a TT kit any day!
Old Oct 16, 2013 | 10:57 AM
  #184
bachelor's Avatar
bachelor
New tune
Alvin’s Badass 450whp Stillen G37 : OnPoint Dyno
Old Oct 19, 2013 | 04:11 AM
  #185
SPDCRZ's Avatar
SPDCRZ
Originally Posted by bachelor
So with the headers there is too much airflow? Going to run too lean? That's why your going to upgrade the MAF's?
Old Nov 7, 2013 | 04:24 PM
  #186
Diego@Vossen's Avatar
Diego@Vossen
I love this thread, lots of great info.
Old May 22, 2014 | 12:21 PM
  #187
bachelor's Avatar
bachelor
question..
Just upped the fuel (pump and injectors) and swapped out the OEM cats for test pipes and my car is making less power. Any ideas? Does the charger need the back pressure from the cats? I'm thinking its a boost leak.
Old May 22, 2014 | 02:54 PM
  #188
ANMVQ's Avatar
ANMVQ
EH :/
JK
457
Old May 22, 2014 | 02:55 PM
  #189
ANMVQ's Avatar
ANMVQ
You need to upgrade the MAF's to make more than 450, I bet his voltage was running out . Mine was on Stock manifolds also. Just a handful of other things Enjoy, God I miss that sound
Old May 22, 2014 | 03:53 PM
  #190
bachelor's Avatar
bachelor
I've swapped to the GT MAF's from UpRev
Old May 22, 2014 | 07:44 PM
  #191
G37Some's Avatar
G37Some
So the stillen headers actually helped out too? I had read some threads mentioning the FI LTH actually hurt performance but 450whp is no joke. Look slike you were able to hold 9psi too even with the headers huh?
do you have any rasp from them or did you wrap them to keep the heat in and improve the sound output?
edit; also regarding the test pipes, you definitely have much more free flow. did you retune after getting the TPs installed? your tuner should have access to all that information but if the exhaust is too free flowing you will get more efficiency, but also some of the boost will leak into the exhaust and effectively drop your PSI. I've read stories that it should balance out to equal power with less boost but Ive also heard this platform paired with too free flowing of an exhaust paired to a SC is a rare occurrence where power is actually lost despite the theory behind it.
Old May 23, 2014 | 08:48 AM
  #192
JerseyG37s's Avatar
JerseyG37s
on top of the MAFs you need to upgrade your fuel system... not just injectors and pump.... in order for me to make a lot more power on E85 and 1000cc injectors i had to run a twin fuel pump setup like the GTRs have and a full fuel system return... The MAFs are one thing but if you dont have enough fuel getting to your motor you will lean it out and melt the rings on at least one of the cylinders....trust me i learned the hard way... i had to replace the long block
Old May 23, 2014 | 05:21 PM
  #193
bachelor's Avatar
bachelor
Found a hair line cut in one of the intake tube vacuum lines, this could be the culprit!
Old Jun 14, 2014 | 09:29 AM
  #194
perez519's Avatar
perez519
question guys can I still use my stillen standard light weight pulley on SC set up?
Old Jul 2, 2014 | 04:51 PM
  #195
whiddles's Avatar
whiddles
Okay guys who have this system LOOK OUT!!!!
Long story short I have 18k miles on the kit I bought new from Stillen in 2010 so warranty is up. Well the other day my car hydro locked from Stillen's manifold inter cooler. they told me this is the first that they have seen this issue and I need to buy a new replacement for with with the whole manifold for over $1100. Is it me or is this unreasonable? At this point I think this maybe a flaw in the inter cooler and can cost you a new engine. Buyers beware. .
install was correct according to trent and the valve bodies have no connection to hydro lock as you can see this is an inter cooler issue not valve body. the install was done through a stillen dealer they sent me to get the install done in the first place. the o rings as see in this pick show the rings where in fact installed correctly and somewhere along the line of going to local shops stillen paid for trying to get the car running right may have added it at any point. the car took three years to get running without limp mode with verious tunes. Stillen has been great to me and I am now way saying they are bad. Im clearly posting my newest issue and think all should be aware and give me input on the issue as stated in post.
Originally Posted by future370zzz
How can you tell if it's RTV silicone or just the o-ring that has melted from the heat-soaked manifold?
I'm not a mechanic so that's why I ask.
its the o rings that were in the kit. ill get a better pic but her is one i got before i cleaned the peals off.
