RPM drops and stalls after startup
Old Oct 25, 2009 | 10:11 PM
Kev G37S's Avatar
Kev G37S
Hi, I've been noticing lately my car is acting weird. This only happens after the car been properly warmed up. For example, After I turn my car off and come back like 15-20 mins later then I start the car and the rpm needle drops like its about to stall and comes back to the normal idle point. My car actually stalled out today cause of this!!! I'm positive that I floor the clutch every time when I push the Start button. Any inputs? Thanks!
Old Oct 26, 2009 | 10:03 PM
shabbo's Avatar
shabbo
maybe your VVEL rockers are getting stuck?
I notice that when the engine is cold started (in California that's not very cold) , if you just tap on the accellerator pedal 'ever so gently' it causes the engine to behave erratically for a few seconds...
Old Oct 28, 2009 | 06:44 PM
AJQuiles's Avatar
AJQuiles
Had same problem. The car was serviced UNDER WARRANTY, they cleaned and reprogrammed the throttle valves. No more stalls!!! Hope this may solve yours.
Old Oct 28, 2009 | 07:06 PM
da mayor's Avatar
da mayor
what gas r you using?
Old Oct 28, 2009 | 07:31 PM
Mike's Avatar
Mike
Typically, a ECU reset will fix this.
Old Oct 28, 2009 | 08:10 PM
ucla bruin's Avatar
ucla bruin
Happens to me too. Haven't taken it in because I have a CAI I'm afraid they're going to complain about. Will try resetting ECU first.
__________________
Old Oct 28, 2009 | 08:12 PM
Mike's Avatar
Mike
I should add, if you're doing an ECU reset, PLEASE make sure you're on 91 fuel, and no additives in the tank (cleaners, octane boosters, etc.)
Old Oct 28, 2009 | 10:23 PM
Staples's Avatar
Staples
I had the same issue. When I shut the car off, and turned it back on it was hesitant for a few seconds and I was getting a knocking noise which sounded like an oil pressure issue. I switched to Motul X-maxx 5w30 which is ester based, I haven't had a problem since.
Old Oct 29, 2009 | 03:57 PM
G37Rider92649's Avatar
G37Rider92649
The Guru speaks
Old Oct 29, 2009 | 04:02 PM
Mike's Avatar
Mike
I don't promise results... just happens to be the fix maybe 80% of the time.
Old Dec 3, 2010 | 09:19 AM
delfin2003's Avatar
delfin2003
This is happening to me again! My car stalled twice last week before starting up finally. Anobody had this issue fixed?! I need to know so I can tell my dealer what to do. Anybody?
Old Dec 3, 2010 | 09:32 AM
Weiboy718's Avatar
Weiboy718
Try cleaning the throttle bodies.
A few members here went through the same symptoms as you And it was simply the throttle bodies was dirty
Old Dec 4, 2010 | 10:34 AM
saltfish's Avatar
saltfish
Do you have On HFC?
Old Dec 4, 2010 | 01:12 PM
EnviedG35's Avatar
EnviedG35
^...This
Old Dec 8, 2010 | 08:06 PM
Q8y_drifter's Avatar
Q8y_drifter
Try this...
https://www.myg37.com/forums/d-i-y-i...le-bodies.html
vamarris
Dec 9, 2018 11:10 AM
Rybitron
Nov 18, 2015 03:11 PM
BurtoN86
Sep 30, 2015 03:32 AM
Allboutcali
Sep 26, 2015 03:43 PM
