Drivetrain Reviews of clutches, gear mods, diffs, axles etc..
Review Bell Raceworks rear differential brace
Old Jan 20, 2019 | 05:57 PM
  #61
Arthur.bell's Avatar
Arthur.bell
If you have a good wobble you should be able to squeeze thru with a short extension, won't be NASA torque accuracy but pretty close
Old Jan 21, 2019 | 01:40 PM
  #62
VIVID's Avatar
VIVID
Pyroclastic Flow
Reintroduction to MyG37 By Way of This Intriguing Mod
I've found myself with a bit of free time (between work projects) and have read with this thread great interest.
So much so, that I have the OEM-cover version diff brace on the way from Bell R/W. It won't surprise anyone who's familiar with me from days past that I opted for a red one.
Thanks to all for the research and feedback on this. I appreciate the inspiration.
Sean
Last edited by VIVID; Jan 21, 2019 at 04:33 PM. Reason: Correct contractions (ie" ' ") posted on a mobile device that don't render properly on desktop instance.
Old Jan 21, 2019 | 11:50 PM
  #63
bPChaos's Avatar
bPChaos
Mine came in - it's the OEM cover one, in red. The initial packaging is a peculiar shape.
A few more images here: https://imgur.com/a/ZVmzc48
Will get more pictures this weekend when I have some time to install.
Old Jan 22, 2019 | 10:10 AM
  #64
4DRZ's Avatar
4DRZ
That is a peculiar shape indeed. I can just imagine the conversation with a significant other, "No honey, I swear it is a car part!"
Old Jan 22, 2019 | 10:38 AM
  #65
Brings an entirely new meaning to noise, vibration and harshness.
And now back to our regularly scheduled program.
Old Jan 22, 2019 | 01:26 PM
  #66
JSolo's Avatar
JSolo
Just say no!!!!!
It's all in the packaging..........
Old Jan 23, 2019 | 11:29 AM
  #67
slartibartfast's Avatar
slartibartfast
My mount arrived yesterday, heading off to have it and a custom catch can system installed shortly.
Old Jan 23, 2019 | 12:28 PM
  #68
Entcee's Avatar
Entcee
Looking forward to your initial thoughts once installed. I have to wait until it warms up a bit to install.
Old Jan 23, 2019 | 04:10 PM
  #69
slartibartfast
Initial thoughts are: what brace? No increase in NVH. Throttle does seem a little more direct but not night-and-day. I attribute this to the fact I have urethane diff bushings/subframe collars and a 7AT. The auto trans tends to take up what little compliance remains in the bushings so the brace isn't obvious. 6MT owners, and those with OE bushings should feel more of a change. I don't have a track event lined up yet, maybe I'll notice more of a change when I get on the track.
My installer epoxied (JB Weld) the bolt to subframe to ease that headache.
Old Jan 23, 2019 | 04:49 PM
  #70
Entcee's Avatar
Entcee
I have the Whiteline (urethane) diff bushings, and the Z1 collars. Will be interesting to see how similar my results are being that the only difference is 7AT vs 6MT (and diff bushing brands).
Do you mean, he epoxied the nut/washer/welded thing inside the subframe? I think that the bolt/washer may be too small and might pull through the subframe?
Old Jan 23, 2019 | 05:43 PM
  #71
slartibartfast
I didn't watch the install but mentioned beforehand he might have to tape the nut to the wrench when threading it. He chose to epoxy it to the subframe with my approval and made no mention of possible pull-through.
Old Jan 23, 2019 | 05:49 PM
  #72
Keep it coming. The first people in here are the ones who set expectations for the rest of us Winter Hermits.
Old Jan 24, 2019 | 07:57 AM
  #73
jpowersjr2's Avatar
jpowersjr2
My brace has had 24 hours now to dry after I applied about 5-6 coats of clear gloss rust protector. I'll be installing it in the next few days. I'm waiting on the roads to get dry so I can do a couple pulls and launches to see what it's like before and after the brace.
Old Jan 24, 2019 | 12:19 PM
  #74
slartibartfast
The auto trans tends to take up what little compliance remains in the bushings...
To be clear, unless the transmission is in neutral, power is always going to the rear end. Even when stopped, as long as the car is in gear, power is being sent to the rear. This constant application of power at a stop takes up what compliance there is in any driveline bushing so there is is little noticeable change in throttle feel when taking off. Unless you try hard, most street driving will not involve quick on/off throttle applications so, again, the diff brace isn't really noticeable. Thus, 6MT owners will feel more of a change as they engage and disengage the clutch.
Old Jan 24, 2019 | 12:21 PM
  #75
slartibartfast
Even though this is a "meh" upgrade for me, it was worthwhile as the mechanic spotted a broken ABS sensor.
