Need opinions on stereo install
Old Oct 18, 2005 | 12:10 PM
Moog's Avatar
Moog
Right now I'm debating on what to do. I have the 4080 sub box and two mismatching amps that I was going to use. One for the sub and one for the Focals I have. Since they were mismatching, I was going to do a stealth install to hide them away.
After coming back from the show and seeing everyone's sweet systems, I'm really tempted to sell these amps to get something matching for a little more show quality setup. Only reason I was going to use these amps was b/c of money issues. One amp I got for $100 and the other I have leftover from my old car. If I get new amps it'll probably run at least $600.
Can't decide...
Old Oct 18, 2005 | 12:19 PM
hyperlitesmu's Avatar
hyperlitesmu
If you went for a show look then you would almost certainly have to have matching amps, but if they were in a stealth type amp rack it wouldn't matter cuz no one would see them. With the 4080 box it is more of a stealthy type of box anyway. You might want to hide everything as much as you can. If you really wanted people to see it and hear it. I'm not sure if a 4080 box will be as eye catching as a custom floor mounted sub or a custom enclosure in the rear of the trunk. That's something that you will have to decide on your own.
Old Oct 18, 2005 | 12:33 PM
Moog's Avatar
Moog
Yeah I guess the point of 4080 box is more of an OEM look, and that's what attracted me to it in the first place.
Old Oct 18, 2005 | 12:40 PM
hyperlitesmu
I think since you already have the 4080 box you may want to tear off into the stelath look and not worry so much about the different amps to save you money and continue with the stealthy "theme" you started when you picked up the 4080 box in the first place.
Old Oct 18, 2005 | 12:56 PM
Moog's Avatar
Moog
agreed...thanks for the advice man
Old Oct 18, 2005 | 01:01 PM
hyperlitesmu
Have you thought about where you were going to mount the amps yet?
I mean the spare tire area seems like a pretty decent spot for you because the donut in there is kind of worthless now that you are rolling on dubs. Either that or you can raise the trunk floor with a light weight wooden spacer and cut amp spaces in them. Or you could do the same thing on the back of the passenger seat. Or you could mount them under the 2 front seats. It depends on how hardcore you are going to be with it.
Old Oct 18, 2005 | 01:36 PM
Moog's Avatar
Moog
That's my dilemma I'm facing right now. I'm not sure if they'll fit on the rear seat back. I've kinda propped them up and it doesn't look like both will fit side by side. I think their too big for under the seats also.
I'm going to meet w/ an installer later today to discuss my options. I don't want it to look ghetto and like it had been thrown together. Man I should really just install myself. I've already partially installed the front components.
http://www.g35driver.com/forum/showthread.php?t=71521
Old Oct 18, 2005 | 01:56 PM
hyperlitesmu
Huh.....What about stacked on top of eachother in the spare tire space? The issue you run into there is definately heat. Youd have to watch yourself there.
Old Oct 18, 2005 | 02:04 PM
Moog's Avatar
Moog
4080 actually mounted an amp underneath his rear deck. So maybe one there and the other on the seatback.
Old Oct 18, 2005 | 02:06 PM
hyperlitesmu
True because both of them on the seatback would look funny if they were different amps. But if it is only one on the seat back no one will ever know the other one isnt the same type. Sneaking Moog I like your thinking.
Old Oct 18, 2005 | 02:41 PM
Moog's Avatar
Moog
so sneaky
Attached Thumbnails Need opinions on stereo install-anonymous-muttley-5001058.jpg
SBG37
May 5, 2022 10:35 AM
ScrewstonNismo
Feb 13, 2022 12:39 AM
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
sharmelan
Aug 25, 2015 03:41 PM
cparise
Aug 19, 2015 01:51 PM
