DIY: Checking Your Oil Pressure
Old Nov 19, 2015 | 01:01 PM
  #46
willguy's Avatar
willguy
Thanks, but I thought it need to be over 100psi since the oil pressure in our car often exceed 100psi. Did I missed something here?
Old Nov 19, 2015 | 02:05 PM
  #47
That J&P gauge goes right to the oil fitting on the side of a motorcycle so you can see it when looking down on the motor, you'd need quite a bit of fabrication for it to work on a G.
I'll shoot some pics and post tonight of my gauge setup.
Old Nov 19, 2015 | 02:07 PM
  #48
m3clubracer's Avatar
m3clubracer
I was just posting a small one that can be obtained. I prefer an analog gauge and will look for a small one that can mount "somewhere" in the car. I did a quick search and will keep trying.
Old Nov 19, 2015 | 06:33 PM
  #49
Yeah, I saw that one and was hoping something real small could be found and I prefer analog too, but luckily this one is pretty unobtrusive~
I just wrapped some bunched-up electrical tape to get some width around that prong so it's a snug fit in that fob slot, and a little extra flat tab (protected w/ some tape to keep from scratching) so it will be tight against the dash molding to the left of the slot
Old Mar 17, 2016 | 10:35 AM
  #50
si_driver's Avatar
si_driver
Hi, Guys,
I just bought this oil pressure gauge and am a little confused on how to wire it up. The instructions are not really clear - at least to me:
Amazon.com: Auto Meter 2634 Z-Series Electric Oil Pressure Gauge: Automotive Amazon.com: Auto Meter 2634 Z-Series Electric Oil Pressure Gauge: Automotive
Can anyone give me some pointers how to wire this thing.
thanks,
Old Mar 17, 2016 | 05:19 PM
  #51
JSolo's Avatar
JSolo
Just say no!!!!!
You'll need to fit the sender unit into an appropriate oil passage.
Are you in need or 'wiring' assistance or how/where to hook up the sender?
Old Jul 11, 2019 | 11:37 AM
  #52
mdanish4's Avatar
mdanish4
Need help!! I had to change my pressure switch. I followed this instruction just to remove and replace the sensor. While removing the old sensor the housing where the sensor screws in broke in two pieces. Sensor and pieces fell. I do have my own thread regarding this. Ehat should i do in this situation. Please help. No i did not hammered
Old Jan 16, 2020 | 07:21 PM
  #53
PNW_IPL's Avatar
PNW_IPL
Anyone know how to get the photos back? I need them to install.
Victory
17
Oct 27, 2022 03:45 PM
4DRZ
Oct 2, 2015 09:54 AM
Redfire32
Oct 1, 2015 04:49 PM
Oh My G 523
14
Sep 26, 2015 07:11 PM
steven92
Sep 18, 2015 12:04 AM
