DIY: Checking Your Oil Pressure
Old Aug 13, 2015 | 10:59 PM
  #31
micafd3s's Avatar
micafd3s
how much more difficult or easier is it to just replace the offending gasket as opposed to doing this..
i mean... if we knew the cause.. why not fix it than installing a monitoring tool to wait for it to fail..
Old Aug 14, 2015 | 08:37 AM
  #32
From what I've read it's 18 hrs of labor give or take
If this were to happen to mine I guess I'd take a week off of work
Old Aug 15, 2015 | 01:02 PM
  #33
Maelstrom's Avatar
Maelstrom
So if we had to replace our engine (been following 35Sport's thread here), does anyone have the part number for the upgraded gasket?
Old Aug 15, 2015 | 07:15 PM
  #34
35Sport's Avatar
35Sport
Here you go...
Also, here's the thread that explains a lot. Page 9 has some disassembled shots.
Cause for the dreaded P0011/P0021 codes that everyone is curious about - G35Driver
Old Aug 18, 2015 | 06:59 PM
  #35
Gia_37s's Avatar
Gia_37s
Hi Guys,
So i've been reading up on these paper gaskets being a problem and i want to look into monitoring OP. Has anyone installed a OP gauge lately? Is there any advantage or disadvantage going with oil sandwich filter vs block galley plug?
not too many Diy's on the this. Even though this original post was very helpful.
thanks guys
Old Aug 27, 2015 | 01:40 PM
  #36
Gia_37s's Avatar
Gia_37s
[IMG][/IMG]
Got my defi racer gauge installed last night. It's installed in it's temporary location the sender wire was way too short, an extension wire is on order. I plan to mount it up on the steering column. If anyone is considering installing one and has questions let me know.
Old Aug 27, 2015 | 03:37 PM
  #37
micafd3s's Avatar
micafd3s
wish they made aftermarket heads up displays..
Old Aug 28, 2015 | 01:07 AM
  #38
35Sport's Avatar
35Sport
I was thinking of going with this setup. I would custom mount it to look as OEM as possible.
Oil Temperature LCD Based Gauge
Oil Pressure Sensor / Sender
Old Nov 5, 2015 | 12:00 AM
  #39
willguy's Avatar
willguy
Is a 100psi gauge sufficient?
Old Nov 18, 2015 | 09:47 PM
  #40
Thanks a lot for this DIY Cliff, installed my guage w/ the glowshift adapter and your grounding trick. Everything worked well and thankfully my oil pressure was very strong never got below 30 and was as high as 124, w/ a cruising PSI of around 70+ at 2k rpms. I'll be taking it on a decent road trip soon so I'll have better data then.
Old Nov 18, 2015 | 09:51 PM
  #41
Here's a post w/ ALL the parts #s for a complete repair including timing chain replacement. Previous posts in the thread below also detail the repair steps.
https://www.myg37.com/forums/g37-sed...ml#post3967871
Old Nov 18, 2015 | 11:11 PM
  #42
willguy's Avatar
willguy
What gauge do you guys use? I am trying to get a decent cheap gauge. Any recommendation?
Old Nov 18, 2015 | 11:27 PM
  #43
Here's the one I got, it's definitely cheap but w/ the grounding trick that VQSmile details it's working well. Only downside is it comes w/ very short wires so you'll have to splice in some longer ones. I just modified the gauge mount clip so I could just slide it into the keyfob pocket on the lower left panel. Out of the way and easy to remove and no drilling or cutting of any dash pieces.
2" Digital Oil Pressure Meter w/sensor Blue LED Display Smoke Lens 0 to 120 PSI - Other
Time will tell
Old Nov 18, 2015 | 11:45 PM
  #44
willguy's Avatar
willguy
Time will tell
Thanks. You do not need to drill anything in the pocket? How do you secure it then? Could you post a picture of it?
Old Nov 19, 2015 | 08:00 AM
  #45
m3clubracer's Avatar
m3clubracer
V-Twin Manufacturing Mini Oil Pressure Gauges | 570-101 | J&P Cycles
