DIY: Whiteline Differential bushings
Old Apr 28, 2015 | 10:09 AM
  #106
krazyfiend's Avatar
krazyfiend
I have acquired a diff (migrating to vlsd and 3.69FD) and am about to go the same route as detailed so awesomely in TVPostSound.
I like the finned Nismo cover and wondered, did you need the additional breather tube and mounting bolt I see Z1 and others offer up or could you just re-use what existed already on your oem diff? I noticed in one of your pictures the diff cover with the breather tube still in the pkg from nissan and that you used what looked like a new mounting bolt, so i assume you ordered both up. Thanks for your time and any insight you can provide.
Old Jun 8, 2015 | 04:10 PM
  #107
Dough1397's Avatar
Dough1397
I'll be replacing the diff bushing soon. I am making a list of parts needed for this job.
1. Are there are any exhaust gaskets that I should be replacing when I button it all back together?
2. Are there any bolts that known to be troublesome (i.e., break)?
EDIT (07-15-2015):
I can answer my questions above.
1. The exhaust gaskets are stainless steel looked fairly good when I removed them. Blnewt (Brad) mentioned they're beefy and can be reused. I would agree despite having what appears to be an exhaust leak (will be checking bolts and seating of flanges at the front of the center muffler soon).
2. All the exhaust bolts needed to be replaced. It's a rough life for a car in the rust belt :P. M10x1.25x35mm works well, 30mm ought to be fine as well.
Replacing the exhaust bolts is not pleasant. After dropping the center muffler, we used an angle grinder to cut the stud flush to the exhaust flanges (did this on both sides). After this, we center punched, drilled a small hole, and stepped up the drill bit size. Cobalt drill bits worked better than the crumby titanium or high speed steel bits. Go slow, apply moderate pressure, use some cutting oil, go straight!!! Once the hole was large enough we used a punch and hammer to knock out the outer edge of the stud.
We also broke the the 10 mm bolt holding up the plastic piece covering the sway bar mounts. I used vice grips to remove these. One 12 mm bolt also broke off. There is no access to the rear of this bolt and it had to be drilled out and will be done in the future.
Old Nov 22, 2015 | 05:03 PM
  #108
jbklyn829's Avatar
jbklyn829
Flipping the bushing
Update:
I just got back from Fast Intentions (New Exhaust), took a 35 mile drive. With the window open!!!!!
Exhaust sounded great, something was not feeling just right.
There was a phasing feel/sound in the car.
Further investigation, revealed the exhaust pulses were out of sync against a driveline vibration.
I never felt that before!!!
Long story short:
I decided to alter the position of my differential bushings, with and without the "top hat" washer.
Bottom line:
I ended up with the thicker bushing on top, thin bushing on bottom using the large washer, with no top hat washer above the top bushing.
With the old exhaust, I though I just had a little NVH.
Do you have the G37s with the 6MT? So did you end up keep the bushings flip upside down?
Old Nov 26, 2015 | 08:39 PM
  #109
jbklyn829's Avatar
jbklyn829
Just finished installing my whiteline differential bushing. I also replaced my differential cover.
Front two differential bushing in this order = large bushing , thin bushing, washer.
Did not use top hat or rubber insulator. I did not hear any NVH or vibration so far.
Old Feb 16, 2016 | 04:49 PM
  #110
ToXIc's Avatar
ToXIc
Originally Posted by JT2014
I don't want to deal with the issues with pinion angle & top bottom bottom top washer no washer bs for the diff. I only want to install once & not have to play with bushing mounting to fix it
If the frame one is the one that leaks & goes bad I want to just replace that 1.
i'm with this guy.. can i not just use the rear and keep the oem ones up front?
btw.. whats "NVH"
Old Feb 16, 2016 | 05:28 PM
  #111
Gregor12's Avatar
Gregor12
btw.. whats "NVH"
Just follow the instructions from white line man. I followed them and don't have any issues. Sure you can just replace the subframe bushing. But why not do both.
Old Feb 16, 2016 | 05:39 PM
  #112
ToXIc's Avatar
ToXIc
Gotcha. But the back and forth between the two methods had me concerned.
Old Feb 16, 2016 | 06:47 PM
  #113
Gregor12's Avatar
Gregor12
Yea same here. But I called Whiteline and a few local shops and none of them said anything but to follow instructions from Whiteline and that I shouldn't have an issues. I don't get any vibrations or noises. Also, make sure everything's connected and hand tightened before tightening the drive shaft and mounts all the way.
Phil
Old Feb 24, 2016 | 07:31 PM
  #114
cougarxcguy's Avatar
cougarxcguy
I did the z1 dif upgrade with the cover and whiteline bushings. I thought i may be able to remove the rear crossmember bushing with a puller kit but was very unsuccessful. There is no way around cutting the old bushing out of the crossmember with a sawzall. I thought that I would add this just in case someone else had the idea to use a puller kit like i did
Old Feb 25, 2016 | 08:55 AM
  #115
Gregor12's Avatar
Gregor12
I used a sawzall. But i went in from the front. I also have a sedan though. After cutting out the center ring I still need a type of puller to get it out. Welded up some 1 inch tubing and used a long bolt to go through the bushing and used the large silver diff bushing to pull it back through. The sawzall will works but you just have to cut at an angle. And I was using the full size freaky sawzall lol. But honestly I don't recommend this to a lot of people. Search for "diff bushing puller Nissan and Infiniti" and there's a guy that sells them specifically for our car. Well worth the buy if you're gonna do the mod.
Old Mar 21, 2016 | 01:21 PM
  #116
sev1980's Avatar
sev1980
Hey everyone,
So I have a EX35, which just blew the rear diff bushing and leaked silicone everywhere. Not too happy about it as I discovered the official fix is to replace the entire subframe.
I did some research and the EX35 subframe is the exact same part number as the G37. While I am mechanically inclined, I dont think I can handle this job myself.
Is there anywhere in San fernando valley in So cal that is a nissan/infiniti specialist/general mechanic that would be able to perform this job for a nominal fee?
My usual indy mechanic says he wouldnt be able to this job. So looking to see if I can find someone experienced in this issue do it..
Old Mar 21, 2016 | 01:54 PM
  #117
caacosta's Avatar
caacosta
Originally Posted by sev1980
Hey everyone,
I went to Donald over at Carzone to get mine done. He's in Van Nuys.
Old Mar 22, 2016 | 12:19 PM
  #118
sev1980's Avatar
sev1980
thank you !! I gave him a call, he stated on a auto trans car its not a huge deal to leave it as is.
Would you guys agree with that?
Old Mar 22, 2016 | 01:30 PM
  #119
Gregor12's Avatar
Gregor12
Most people with autos don't give the bushing the same abuse as the MT owners due. But if you drive spirited it's still a possibility it would break or bust. I would just drive it until it leaks of it ever does.
Old Mar 22, 2016 | 01:31 PM
  #120
sev1980's Avatar
sev1980
yeah mine did break and leak, which i was surprised..
