DIY: Change your spark plugs
Old Aug 8, 2019 | 04:31 PM
  #91
GodlikeRage's Avatar
GodlikeRage
So how many turns from finger tight is good for the plugs?
Old Aug 13, 2019 | 05:54 AM
  #92
larramo's Avatar
larramo
spark plug can last up to 100.000 miles i use Barrymans b12 in my g37 it is good stuff gets rid of all carbon deposits in the plentum cat converter really anywhere the fuel gos i swear by it especially now that gas in ca gose bad in 5to7 days i use it in my mower never have to drain the tank before i use it. Larramo
Old Aug 13, 2019 | 01:57 PM
  #93
BULL's Avatar
BULL
Moderador
Any one have good feedback on the NGK ones for this? Nissan went from NGK to Denso in the vq37 however I would like to run the NGKs for a couple of months to compare.
Old Aug 13, 2019 | 02:05 PM
  #94
GodlikeRage
NGK lasts longer, Denso performs better
Denso > NGK because of the difference in longevity compared to each other is negligible.
Old Oct 9, 2019 | 03:07 PM
  #95
vqruby's Avatar
vqruby
great write up, just did mine a week ago
Old Oct 18, 2019 | 04:59 AM
  #96
Illmoja's Avatar
Illmoja
Question for anyone who done this DIY: Is it ok to use a 12 pt spark plug socket to remove and install plugs which has 6 pt hex? Finally having a free time after this weekend.
Old Oct 18, 2019 | 06:00 AM
  #97
Surfnazi's Avatar
Surfnazi
6 point that has rubber catcher inside
Old Oct 18, 2019 | 08:40 PM
  #98
Illmoja's Avatar
Illmoja
I see. Does it have to be a thin wall socket?
Old Oct 19, 2019 | 04:50 PM
  #99
Surfnazi's Avatar
Surfnazi
No regular works fine, only my m3 ever required thin wall special made for bmw socket
Old Jan 12, 2020 | 03:06 PM
  #100
Rollo's Avatar
Rollo
Denso's website says they discontinued the FXE24HR11.
Rock Auto has them out of stock and my initial searches for the plug using FXE24HR11 on Advance Auto and Autozone web site brought up no results. However, you can put your car in and search for plugs and they will come up. Also available from NAPA....
I didn't find any good sales on them though--15 each was the best I could find other than a sketchy looking 6 pack on Amazon for like 30 bucks.
Old Oct 2, 2021 | 10:55 AM
  #101
waynerd313's Avatar
waynerd313
Replace or Not to Replace
I just purchased a pre-owned 2013 G37 Sedan and I've been going through all of the neglected maintenance items. The engine has 108K miles so I'm at the suggested replacement interval for the spark plugs. However, there were no maintenance records so I decided to pull a plug and take a look at one before ordering new ones. Based on the pictures below, what would you guys say to do? Replace them or wait?
Old Oct 2, 2021 | 04:13 PM
  #102
rotarymike's Avatar
rotarymike
Moderator in Moderation
That one doesn't look that bad (insulator and conductor) but the burn marks on the ceramic ABOVE the nut concern me.
Old Oct 2, 2021 | 04:51 PM
  #103
JSolo's Avatar
JSolo
Just say no!!!!!
^^You think that's burn marks? I thought it was corrosion.
Old Oct 2, 2021 | 05:34 PM
  #104
waynerd313's Avatar
waynerd313
I thought it was rust but I don't really know anything about it so I thought I would post some pictures and get some feedback. In any case, they look pretty old to me so maybe I should stop overthinking it and just replace them.
Old Oct 3, 2021 | 12:01 PM
  #105
rotarymike's Avatar
rotarymike
I suppose that could be corrosion infusing through the ceramic. Looked like burn marks to me but it could even just be oil deposits from the spark plug well - those gaskets are known to be leaky.
