DIY: Installing window trim vinyl wrap 07+ G Sedans
Old Oct 28, 2016 | 11:04 AM
  #151
MaQG37's Avatar
MaQG37
Originally Posted by Dembflyr
Thanks for the write up. It helped a bunch.
Looking good...next up...headlights.
Old Oct 28, 2016 | 12:49 PM
  #152
Dembflyr's Avatar
Dembflyr
For sure. They are on the list for spring.
Old Apr 21, 2017 | 08:24 PM
  #153
kc_pig's Avatar
kc_pig
Just making sure, the drawing schematics by BLNEWT will work for a 2010 G37 sedan right? I just got the blk carbon fiber to do my dark gray G37.
Old Apr 21, 2017 | 09:27 PM
  #154
Yep, no changes from 2007 G35 sedans through all G37 Sedans, the Q50 is a no-go though.
Old Jun 1, 2017 | 05:17 PM
  #155
kc_pig's Avatar
kc_pig
Just the grille and grille emblem left. Not sure if I'm going to even jack with putting the lettering back on the rear. I tried to vinyl wrap those..... Well, I started/stopped after the G turned out looking like crap. If I decide to put them back on, I'll gloss black them and trace the letters and put the vinyl on the front face of the letters instead of wrapping the sides too. Corners are a B.
Attached Thumbnails Installing window trim vinyl wrap 07+ G Sedans-20170425_122713.jpg   Installing window trim vinyl wrap 07+ G Sedans-20170530_173737.jpg   Installing window trim vinyl wrap 07+ G Sedans-20170530_173755.jpg   Installing window trim vinyl wrap 07+ G Sedans-20170531_132516.jpg
Old Jun 2, 2017 | 12:02 AM
  #156
Window trim looks great, the lettering is a tough wrap. Plasti-dip is actually a good product for small pieces like those. Might be worth a shot, and just leaving the Infinti logo back there without all the letters looks really good IMO and makes it much easier to detail
Old Jun 24, 2017 | 06:15 PM
  #157
kc_pig's Avatar
kc_pig
Finally
Thanks BLNEWT for the tips. Only thing left is the fog light trim which I'm leaning toward painting black. One thing I've learned doing this to my entire car is that TIGHT CURVES SUCK!
Screwed up in one place on the grille. Did the emblem 2 weeks ago and the entire grille took about 4-5 hours today. Use a lot of heat and push between the louvers, cut 1/4" below each louver and you're good to go.
I decided to spray paint the inside where I thought the vinyl might not cover when I cut and I'm glad I did. The vertical columns behind the louvers were already a sheen black/chrome color but the paint made it completely black. Probably use that stuff on the fog light covers. I'm including a picture of where I screwed up on the lower left side. I did a decent job at fixing it but I was about to walk into my driveway and start cursing after doing such a good job on the right side.......
Added a pic of the back too.
Attached Thumbnails Installing window trim vinyl wrap 07+ G Sedans-20170623_180029-1-.jpg   Installing window trim vinyl wrap 07+ G Sedans-20170624_102406-1-.jpg   Installing window trim vinyl wrap 07+ G Sedans-20170624_102519-1-.jpg   Installing window trim vinyl wrap 07+ G Sedans-20170624_132548-1-.jpg   Installing window trim vinyl wrap 07+ G Sedans-20170624_153152-1-.jpg
Installing window trim vinyl wrap 07+ G Sedans-20170624_153228-1-.jpg   Installing window trim vinyl wrap 07+ G Sedans-20170603_180242.jpg
Old Jul 4, 2017 | 06:18 PM
  #158
QuinnDEskimo's Avatar
QuinnDEskimo
Thanks for this write up!! There's definitely a learning curve to using the vinyl but after doing this, if I had another chance, it'd be perfect. It looks good though and there's no sense in me rewrapping anything. Thanks again for the awesome template!!!
Old Jul 31, 2017 | 12:15 PM
  #159
LmtdSlip's Avatar
LmtdSlip
Tips on wrapping the chrome tail
Any tips on wrapping the chrome tail?
Did you remove it from the car?
How did you do the camera and button?
Thanks!
Old Aug 14, 2017 | 05:44 AM
  #160
ballz3's Avatar
ballz3
Thanks!
I did mine from the top down, with it on the car. I would recommend starting at the bottom in order to better get it around the camera first; at least that how I'll try it next time (I plan on doing it again to fix some imperfections).
I used an Xacto knife to cut out the camera after the application was done.
Old Aug 27, 2017 | 07:04 PM
  #161
kc_pig's Avatar
kc_pig
that's what I did. Cut an excess of about an inch and start at the top and squeegee down. I just cut the button out and camera out after pressing. There's enough room around the spoiler for you to tuck and use an exacto knife to cut. I actually thought that was easier than the trim.
Old May 4, 2020 | 03:20 AM
  #162
Z33_SPL's Avatar
Z33_SPL
Finally got around to doing this after all these years. My window trim and b-pillars were so beat up. It took me about 5 hours but it was definitely worth it. Thanks blnewt!
Old May 4, 2020 | 11:48 AM
  #163
Scarab Armor's Avatar
Scarab Armor
I'm in a similar situation. I've had my vinyl for years, but I have yet to apply it. I was going to finally do it yesterday, but I decided to address issues with my horns and grille instead. Your pics have definitely given me the push I needed. I will tackle mine this weekend. Your car looks great!
Old May 4, 2020 | 12:20 PM
  #164
ballz3's Avatar
ballz3
Looks good! haha I'm ALSO in the same boat. I boat mine probably 6-7 years ago after this thread was started....all I've done so far was the trunk lid spoiler, and that was 3 summers ago! haha doh! Time to get it done! Although I'm probably getting rid of the G within 12 months.
superjoey
31
Mar 22, 2023 11:56 PM
G37xhibeet
Nov 15, 2016 09:29 AM
Morgan Thompson
Aug 19, 2015 04:44 PM
