how do you adjust the windows.
Old Jan 25, 2010 | 10:10 PM
ak47's Avatar
ak47
hey guys getting air noise and water leaking in alittle from window. how do i adjust the window. i keep going to the dealer and there either making it to tight or not tight at all.
Old Jan 25, 2010 | 10:28 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
you should be able to reset the windows by holding all the window buttons down (2/4 if you have coupe/sedan respectively) for >5 seconds then up for >5 seconds
check the manual to make absolutely sure that I have the procedure right but I think I remembered it right
Old Jan 25, 2010 | 10:51 PM
soolman32's Avatar
soolman32
What he said. That is the right sequence
Old Jan 26, 2010 | 06:30 PM
ak47's Avatar
ak47
nah adjusting the window. not resetting it. 2 different things. i am getting water in a little after washes and the door is making a weird noise when closing when it touched the rubber molding.
Old Jan 26, 2010 | 06:42 PM
hispeed-lowdrag
have you tried resetting it? it might be stuck and think its all the way up and then go back to the "normal" position after resetting it.
also, check the rubber molding along the door, it might be dirty/cracked/etc
Old Jan 29, 2010 | 12:24 PM
ak47's Avatar
ak47
does anyone know how to
Old Mar 4, 2011 | 10:01 PM
anh3's Avatar
anh3
I think what he meant was adjusting the window regulator, having the glass edge deepter/less into the rubber seal. I other words, adjusting the window heights. I have the same problem, and apparently its only covered under warranty for the 1st twelve months. One deal wants to charge me $100 to do it.
Old Mar 5, 2011 | 12:07 AM
wakeboardr116's Avatar
wakeboardr116
You have to completly remove the door pannel then there are two little holes on the door frame that you have to take covers off. Then you roll the window about half way down and there are screws to loosen it up and adjust it. I watched the body shop do it to my driver side after I was getting wind noise after some repairs.
Old Mar 11, 2011 | 02:02 PM
1cleanG's Avatar
1cleanG
NextLevel Performance
thanks for the info for resetting the windows guys. Mine got messed up when i had to jump my dead battery
cellwoot
Sep 7, 2018 07:10 PM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
4DRZ
Nov 7, 2015 08:32 PM
Wreckreation
Sep 21, 2015 06:27 PM
moteel
Site Feedback & Suggestions
Sep 18, 2015 08:23 PM
