DIY: Removing Front Grille
Old Jun 7, 2011 | 03:08 PM
  #91
CDONNS's Avatar
CDONNS
I think most people crack theirs because they dont remove or at least loosen the reservoir.
Old Jul 2, 2011 | 08:56 AM
  #92
MaluG37's Avatar
MaluG37
I managed to remove my radiator cover without cracking it. I removed all the bolts (cover and reservoir) and clips (cracked one), also removed the plastic pins on the weather striping over the headlights (broke all 4), and unscrewed the bolt above the headlight. By doing that the bumper was able to flex a lot. My problem is how do you disconnect the wiring harness under the cover without damaging anything? I didn't want to damage anything so I put it all back. Any help guys? The arrows in the attachment below point to some of the wiring harness clips.
Attached Thumbnails Removing Front Grille-wire-harness-under-radiator-cover.jpg
Old Jul 2, 2011 | 01:21 PM
  #93
tharbemiko's Avatar
tharbemiko
For the white clips, just yank it out with a bit of force. That's what I did and there was no damage at all to the clips. For the black ones, use some pliers to squeeze the "hooks" and then gently push it out of the hole.
Old Jul 3, 2011 | 05:30 PM
  #94
MaluG37's Avatar
MaluG37
Thanks...I ended up breaking a bunch of clips on the radiator and bumper so I was afraid I'd do the same with the wire harness. By the way those little pins for the weather striping costs over $4 ea.
Anyone else with suggestions?
Old Sep 22, 2011 | 12:53 PM
  #95
Mrgrimreaver's Avatar
Mrgrimreaver
I just did this last night.
Time: 3 hours
I didn't have the right socket, so i spent almost an hour fiddling around and after my friend brought the socket, BOOM! The bolts came off super easy.
MAKE SURE to remove bolts from the white tank and move it back. Also declip the thick wires under the cover, it will make your job 10 times easier.
I also de-cliped the thick wire from its plug on the bottom left side.
There are 5 bolts to remove after you take the cover off to remove the grill.
When you put it all together, you need to clip back the thick wire first, then make sure you have a little patience and LOTS OF LIGHT. put it back exactly how you removed the cover and pop everything in place.
Overall this was a medium difficulty to a noob like me.
Time if I did it again: 10 minutes
Old Oct 11, 2011 | 08:55 PM
  #96
jeg650's Avatar
jeg650
Just did it. Very easy. Only tricky part was removing the radiator cover to get to the nuts for the grill. Props!
Old Oct 13, 2011 | 11:32 AM
  #97
pgrider91's Avatar
pgrider91
stop hating people
Old Jan 18, 2012 | 01:43 PM
  #98
Dr.Pat's Avatar
Dr.Pat
Subscribed...
Old Jan 25, 2012 | 06:41 PM
  #99
Alan318's Avatar
Alan318
Originally Posted by sTiLLBaLLiN37
Once the radiator is removed, there is going to be some wires connected underneath the radiator cover, if you wish to have more room, declip them from the radiator cover. The wire is shown by the arrows pointing to it.
You meant Radiator cover right? Typo?
Old Jan 29, 2012 | 04:09 PM
  #100
Alan318's Avatar
Alan318
Hi I just joined the "cracked radiator cover club".
Old Feb 6, 2012 | 11:43 PM
  #101
BlkG-37S's Avatar
BlkG-37S
I fear doing this since 3/4 of everyone that did cracked their radiator cover. Geez, I'm unsure if I wanna toggle with this over the weekend now. Is the cover that tough to remove without cracking??
Old Feb 7, 2012 | 01:53 AM
  #102
DTRAN408's Avatar
DTRAN408
Thumbs up
Swwweeettt!!!! Just what I needed to know,, DANKS!!!
Old Feb 7, 2012 | 05:37 PM
  #103
Alan318's Avatar
Alan318
If I had known there were two metal rods that stick through those two holes holding the cover in place...... I would have never cracked it! But you really cant see back there and you assume you can just pull up until you hear the CRACK.
Old Feb 7, 2012 | 08:56 PM
  #104
BlkG-37S's Avatar
BlkG-37S
Alright guys, I couldn't stand watching my midnight grill in my living room so I decided to bite the bullet and install. I couldn't wait so I started at 6 p.m. at night. I took my sweet time to avoid the famous "cracking" of the radiator cover. Well I completed the install in 2 hours without cracking the radiator cover. I removed the wash tank to clear room for those annoying two middle bolts. After some wiggling and pulling, I got a clean removal.
Only minor issue I had was while removing the actual grill the pointy freaking screw on the top of the grill got jammed and then chipped a very small piece of my front bumper as I yanked it out. It's not noticable, but it ruined my "perfect install." I also was left with 1 extra screw when I swear every hole had a screw...lol have no clue how I was left with 1. You guys can avoid cracking the cover if you take your time, that's my only recommendation.
Old Feb 8, 2012 | 01:00 AM
  #105
Meekayal's Avatar
Meekayal
Good write up. I'll be doing this some time this week. Was just checking if there were any secrets
I like the screws better than the clips -_-
