DIY: Removing Front Grille
Old Aug 17, 2013 | 09:41 PM
  #136
RavensMinded00's Avatar
RavensMinded00
Big thanks to the OP for this DIY. In no ways was this rocket science but it helped streamline the process of getting the grille off to paint it. Thanks again!
Old Aug 18, 2013 | 02:11 AM
  #137
Samer Serhan's Avatar
Samer Serhan
did this on a 2010 g37x sedan today (midnight grille install), pretty easy if someones helping
once i got all the bolts off, i tried pulling the cover up and away, but i noticed the coolant tank was in the way, so i just removed the left bolt holding it in place, and that was enough to make it move out of the way. While my brother pulled the front bumper out I pulled the cover up and out with no problems (in the middle of the cover it is secured into two prongs so focus on getting the cover out of those prongs as you pull it off) . The radiator hose is clipped right to the bottom of the cover (around 7 clips) and its near impossible to do any real work if these are not unclipped with needle nose pliers. Once removed, set the cover aside (it was still connected at one spot), and remove the 5 screws holding the grille, then push the tabs and pull it out. then reverse the steps;
OP; thanks for the DIY install took 1 hour
Uploaded with ImageShack.com
Old Aug 26, 2013 | 10:22 AM
  #138
MIBeta86's Avatar
MIBeta86
Hey everyone, just signed up...seems like a great community and an abundance of information here from I've read so far...
So i just bought an 08 g37s coupe/journey with about 38,000 miles...I believe i got a good price for it and it had a clean carfax however after I had couple friends look at it and seeing the pics on this forum, we noticed that he had few parts missing in the front...it seems like it was in an accident.
Anyway, the main thing we noticed that was missing was the radiator cover ....I see everyone had difficulties taking it off but was it easy putting it on?...not sure if I should do it myself as I'm a newbie in any car related work and probably dont have all the right tools.... Should I do this myself?
PS. does any1 know where I can buy 1 and all the necessary bolts, etc.?
Old Aug 26, 2013 | 10:57 AM
  #139
It's an easy install, just have to get all the wiring clips snapped in prior to the final fit of the cover. You need to get it all together and then get it flat where it needs to be and give it a firm push back toward the engine to clear those two hidden plastic pins, push it down over those pins and you're good to go. Here's a source for the shield, it's part # 6 in the diagram and a bit over $50. Welcome to the site BTW, and congrats on your new G!
2008 INFINITI G37 Parts - Discount Infiniti Parts | Genuine, OEM Infiniti Parts | Infiniti Accessories | Huge Instock Inventory
Old Dec 27, 2013 | 06:22 PM
  #140
Deelow's Avatar
Deelow
Nice info. Planning on this DIY when I get home!
Old Jan 17, 2014 | 08:49 PM
  #141
illG13's Avatar
illG13
Has any of you guys removed the lower plastic mesh on the front bumper? If so, how?
thanks
Old Feb 12, 2014 | 04:45 PM
  #142
XraidenX's Avatar
XraidenX
this probably a stupid question but if you are just going to paint the grill could't you take off the radiator cover, tape off the back and put newspaper behind the grill then tape off the front protecting the whole front of the car except the grill, couldn't you just paint the grill then with it still on the bumper?
Old Feb 23, 2014 | 08:18 PM
  #143
Deelow's Avatar
Deelow
Never a stupid question. You can definitely do that , but remember painting in this way can make the paint uneven and can get overspray on your car's paint which you should avoid if possible. Taking the grille out and cleaning it well, prepping the surface (sanding/scuffing and laying it on a raised and flat surface such as a table) works best to avoid runs or avoid making uneven mistakes.
Old Feb 23, 2014 | 10:34 PM
  #144
MrJCole13's Avatar
MrJCole13
thanks
I removed these yesterday. I had the bumper off and they unclog and pop off from the inside of the bumper.
Old Mar 21, 2014 | 12:03 PM
  #145
GraphiteIPL's Avatar
GraphiteIPL
Thank you for the DIY instructions
Just wanted to say thank you for the DIY instructions! Using the guide, I was able to swap out the chrome grill on my IPL with the midnight black version without breaking anything. I am mechanically challenged so that was something of an accomplishment.
Michael
Old Jun 2, 2014 | 10:11 AM
  #146
Gshadow37X's Avatar
Gshadow37X
Grill Removal D.I.Y.
Many thanks to the OP and the other members who improved the DIY by mentioning the problems with the prongs and the coolant reservoir. I just successfully swapped out my grill with the midnight grill in well under an hour. This was with smoke breaks, and not realizing that there were four nuts instead of the two that I could see holding in the actual grill. I love this place!!!!!!!!
Tony
Old Jun 24, 2014 | 01:06 PM
  #147
flipmode007's Avatar
flipmode007
Originally Posted by Mantis
Thanks for the excellent DIY! Removed mine this past weekend to paint it up. Those 2 little bastard prongs suck! But it's finished now and looks so nice
What did you paint it with? and what kind of paint did you use, mine need a touch up to black look so nice
Old Jul 18, 2014 | 05:03 PM
  #148
lcottet7's Avatar
lcottet7
Is it possible to plastidip my grill on my 2013 g37 coupe without removing the front grill ?
Old Aug 21, 2014 | 06:28 PM
  #149
JT2014's Avatar
JT2014
Thanks for this...but getting that radiator trim off was a PITA! I cracked the area where the 2 pins are. Oh well no one see's it.
Old Sep 3, 2014 | 04:34 PM
  #150
cmackin's Avatar
cmackin
I'm about ready to just throw my midnight grille in the trash because I can't get these the radiator cover over these F'ing bolts even with the coolant tank bolts removed.
Things I learned:
remove coolant reservoir
pull shroud up and over two bolts in the middle. I found it was easiest with my fingers underneath where the bolts are, and my palms on the top of the shroud.
You need to remove the thick wire on the bottom. Do this by using a pliers to press in on the sides of the connectors.
Leave the thin wire connected, but make sure you bring it up and over the metal piece that juts out in the center.
Thanks for the DIY, and thanks to MN Nissan Infiniti members for giving me the helpful details.
