DIY: Headlight and Foglight Adjustment
Old Sep 13, 2009 | 08:24 PM
  #31
hispeed-lowdrag's Avatar
hispeed-lowdrag
Thanks for the great write up X, as well as everyone that contributed! I finally got around to doing this...I had forgotten how great the G's lights are, they've been pointing at the ground for so long after my drop!
Old Sep 14, 2009 | 11:03 AM
  #32
Xcalibur's Avatar
Xcalibur
Your welcome man! Glad it Helped!
Old Sep 15, 2009 | 11:17 PM
  #33
mrc's Avatar
mrc
just took a trip to Reno this weekend and hadn't noticed the difference after lowering driving the LA freeways but out there it was DARK and it was like my lights just fell way short of the visibility I remembered - so search brought up the diy and ta da - good as new
thanks for taking the time to do such a great post!
Old Sep 16, 2009 | 03:57 PM
  #34
Xcalibur's Avatar
Xcalibur
Your Welcome and Thanks!
Old Oct 25, 2009 | 10:28 PM
  #35
chasemyaccord's Avatar
chasemyaccord
Awesome writeup, I need to do this once I find a parking garage and some time to spare.
So all I need is a phillips eh? Judging by your second picture I thought I needed to bring my ratchet set, but I guess not.
Thanks!
Old Jan 30, 2010 | 10:28 AM
  #36
ProstylezG37's Avatar
ProstylezG37
Yea I need to do this too..tried adjusting it without the masking tape..everything was way off...
Old Mar 30, 2010 | 11:01 PM
  #37
JoshLee89's Avatar
JoshLee89
Do you know the distance (final adjustment measurement) for S-tech drop?
Like you have pre-determind measurement for S-tech so far?
Old Mar 31, 2010 | 08:43 AM
  #38
Xcalibur's Avatar
Xcalibur
Like you have pre-determined measurement for S-tech so far?
Nope, no one has given me the measurement. you'll have to measure from ground up vertically to center of headlight light and subtract 2 inches... if you do so please let me know what the measurement is so I can put it up for other forum members like yourself.
Old Mar 31, 2010 | 07:41 PM
  #39
JoshLee89's Avatar
JoshLee89
so center of the headlight.. what do you consider center of the headlight.
There is like a sphere thing that shoots headlight beam, center point of the that sphere bulb?
If O is the sphere, half way of O<-- ? which is the middle of the sphere.. am i right?
Old Apr 30, 2010 | 10:40 PM
  #40
whiddles's Avatar
whiddles
I want to adjust mine by eye to be equal. I hate how it only lights up like 15 feet in front of me. Thanks for the info and sorry for the people i blind in advance
Old Jun 30, 2010 | 11:07 PM
  #41
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
That's sounds right. That's how I'd do it.
Old Jul 1, 2010 | 02:58 PM
  #42
sick6speed's Avatar
sick6speed
If i dropped on Eibach Pros and swapped the wheels out to 20s...do you think I would still need to adjust the lights?
Didn't know if the 1.2 inch front dropped and the increase in wheel size would make a difference.
Old Jul 1, 2010 | 03:05 PM
  #43
whiddles's Avatar
whiddles
im dropped on the same set up. i needed to bring my lights up a bit. my headlights seemed to only work about 12 feet in front of me before
Old Jul 1, 2010 | 03:28 PM
  #44
Xcalibur's Avatar
Xcalibur
Yes and sorry for late reply. Dead center of your reflector is your bulb so it shold be dead center of the bulb within.
Yes a 1 - 2 inch drop needs adjustment.
Now as a note to ones with a drop with tire aspect ratios that are not 35 front/30 rear on 20 inch wheels(these aspect ratios are basically like the stock). If larger or smaller aspect ratio. either way the measurement from floor to center of headlight measurement and this DIY will fix the issue regardless of height of tire, just don't use any pre-determined measurements I have at top of my post and do measure it out as the tutorial describes.
Old Jul 1, 2010 | 03:40 PM
  #45
hispeed-lowdrag
it sounds like you are confused about how getting bigger wheels works...the wheel itself is bigger but the sidewall of the tire gets smaller (the aspect ratio) so the overall diameter of the tire+wheel stays the same. If it didn't all kinds of things like your speedometer would be thrown off
hope that helps
(oh and, yes you have to still adjust your lights)
