backyard DIY spring install
Old Jan 19, 2012 | 06:36 PM
  #91
Originally Posted by Kidcane
The fronts on the other hand will definitely kill you without a spring compressor.
I'm with you on this. The DIY posted here and others have said that it's OK to just remove the top nut wihtout compressing the spring first. I wouldn't do that under any circumstance.
Old Jan 19, 2012 | 06:54 PM
  #92
Dr.Pat's Avatar
Dr.Pat
And that's why I'm leaving the fronts to the professionals!
Old Jan 22, 2012 | 12:03 AM
  #93
apexi350z's Avatar
apexi350z
I purchased these two from Harbor Freight Tools and did the springs install today. To my surprise, the electric impact wrench actually works great! I did spray some penetrating oil and let it sit overnight, then when I tried to use the impact wrench, it took about 10 seconds before the nut begin to turn. I was worried for the first 5 sec that it might not work, then it just started to turn slowly, and more afterward. The total install took about 4 hrs for front & back, that also includes the rear camber kits (which was very easy). I will wait until I get the Eibach Sway Bar before get them aligned. Thanks for all the help on this thread!
1. 1/2" Electric Impact Wrench Item #68099 $49.99
2. 13 Piece 1/2" Metric Socket Set Item #67904 $21.99
Btw, I have a 2012 G37 about 3 months old, so the nut that everyone is having hard time to get loose may not be as easy as mine when the car is older. I just want to share my experience with my install, with the tools I used.
Old Jan 22, 2012 | 12:16 AM
  #94
Good to know that the electric impact works well. You don't need to wait for installation of sway bars before alignment, they don't affect the alignment of the wheels.
Old Jan 22, 2012 | 01:48 AM
  #95
shumby's Avatar
shumby
FYI for any canadians out there that want to do this but don't have a spring compressor. Canadian Tire will lend you one for free. well what they do is give you a used one but charge your credit card for a new one. Then when you bring it back they reverse the charges. They do this for alot of tools.
Old Jan 22, 2012 | 02:22 AM
  #96
breftayka's Avatar
breftayka
I'd like to see an electric impact remove the lower strut bolt on a 2008-2010 that has more than 30k miles on it. :P
That thing was hell only on my driver side.
Old Jan 22, 2012 | 09:22 AM
  #97
A number of parts stores in the US do this as well (O'Reilly, Auto Zone, others). It's a great deal for parts that you will only use once or very infrequently if you don't want to buy them. It's about a $50 deposit at most places here.
Old Mar 19, 2012 | 08:51 PM
  #98
Ontario G37S's Avatar
Ontario G37S
Originally Posted by breftayka
Leave it on and just drop the whole arm. Have someone help you. It's a little less safe as the spring will have a little bit of a kick, but it's so much faster and easier. I somehow got my drivers side with a breaker bar, but stripped the passenger side after 25 minutes of switching between an impact with a 6 pt socket and the breaker bar. That thing wouldn't budge...
I agree. I tried 3 days to get this damn nut off and no go. I gave up today and tried to go to a shop and get it done, and well all were busy except the place that scuffed my mint rims. I had no choice but to try them. Well after an argument that it was gonna take them 4-5 hours plus alignment which I told them I'm gonna wait a few weeks to let the springs settle. Finally I just walked out and was pissed enough to try again.
This time I went the "drop the whole arm" way and it was a lifesaver. Saved a few bucks doing it myself. I still used a spring compressor to the OEM spring so it didnt come out like a jack in a box. Those Eibach springs are scary to compress as pretty much you have to go all the way for them to fit correctly. Walking on eggshells for the first side, but much faster the other side (even with installing the sway link nut instead of the actual top hat nut on the strut , I did correct that though).
If anyone else has issues with that bottom strut bolt, this method would probably be a less of a headache.
Old Mar 24, 2012 | 08:35 PM
  #99
dtran2714's Avatar
dtran2714
Followed the posted instruction and was able to do the install with no problems. The rears where very easy to do. The front took a little more work but I was able to get the strut bolt off with a breaker bar.
Old Jul 13, 2012 | 10:18 AM
  #100
mystikal's Avatar
mystikal
just accomplished this last night...for a 11g37x Sedan on Eibach springs
Backs were cake only took about 10 mins with air tools...
Fronts were a PITA...With the X models you have to remove your cv joints an remove the top control arm...
On one side though we removed the Strut Arm (towards the bottom of the strut, one bolt) and it came out much easier...
But heres some pics...I f*ck'd up my cv boot
Before
After
I'll post more later...
Old Jul 15, 2012 | 05:36 PM
  #101
noctilucous's Avatar
noctilucous
A friend and I actually just put the Eibachs in on my 08 G35x on Monday. We began at my house... but then went to his for his air setup. I can't even imagine without it. We just unbolted the upper wishbone and with a bit of pressure pulled the strut out.
Just went to Orileys for a spring compressor as well, easy job overall just time consuming.
Old Jul 17, 2012 | 11:38 PM
  #102
Str8shooter's Avatar
Str8shooter
I removed the struts and had the front springs put on by a local shop. I had trouble lining the struts back into place when I tried to re-install them. Did anyone else have this issue?
Old Jul 18, 2012 | 10:14 AM
  #103
soundmike's Avatar
soundmike
The top hat has to line up with the rest of the strut body properly. The FSM should have the proper diagram showing this.
Most folks would just mark the top with a sharpie so they know where it should be positioned when putting things back together.
Old Jul 18, 2012 | 10:57 AM
  #104
mystikal's Avatar
mystikal
Yeah had the same issue... with one side. But it worked out just fine afterwards...
Old Jul 18, 2012 | 11:12 AM
  #105
Sometimes it lines up perfectly the first try and sometimes it needs coaxing. Having a jack and a rubber mallet helps so you can jack the lower spring bucket up or down and tap it with the mallet to line up the hole for the bolt. Also a long thick screwdriver or something similar helps to put through the hole and push or pull it into alignment so the bolt slides through easily without damaging the threads on it.
